Linuxcnc 2.8 switching kinematics natively?
- 3D-Master
- Thank you received: 5
22 Sep 2020 22:20 #183352
by 3D-Master
Linuxcnc 2.8 switching kinematics natively? was created by 3D-Master
Since Linuxcnc 2.8 is finally out, is the patch from Switchkins natively implemented into Linuxcnc 2.8 to be able to switch from 3 axis trivial to 5 axis simultaneous Kinematics even if the rotary axes are not at 0?
Or short: Can we now switch Kinematics on the fly?
- Thank you received: 2164
23 Sep 2020 06:56 - 04 Oct 2021 15:02 #183414
Replied by Aciera on topic Linuxcnc 2.8 switching kinematics natively?
Switchkins has not been merged into 2.8 or master. If you need to switch kinematics you have to build the switchkins branch.
www.panix.com/~dgarrett/stuff/s_kins_guide.txt
[edit]
'Switchable kinematics' has since been merged with master (aka 2.9pre)
[edit]
Last edit: 04 Oct 2021 15:02 by Aciera.
The following user(s) said Thank You: 3D-Master
Time to create page: 0.111 seconds
