RS274NGC_STARTUP_CODE Question.
25 Sep 2020 00:19 #183655 by rafferty
RS274NGC_STARTUP_CODE Question. was created by rafferty
Am I correct in assuming the RS274NGC_STARTUP_CODE line in an ini file is treated by the g code interpreter as a normal block?
This would mean the order of commands is ignored, they will be executed in the normal priority order.
Specifically a G21 millimetre command is executed before a G64 Pn.n command.
So the G64 P argument unit is millimetes not inches?
This is in contrast to the rest of the ini file which is in inches.
Ken.
02 Oct 2020 11:35 #184562 by andypugh
Replied by andypugh on topic RS274NGC_STARTUP_CODE Question.
Yes, I would assume so.
You have the option of calling a G-code subroutine from that line in the INI, if you want to make this explicit.
02 Oct 2020 20:02 #184614 by rafferty
Replied by rafferty on topic RS274NGC_STARTUP_CODE Question.
Ahhh! Clever thinking, would never have thought of that. Thanks.
Ken.
Time to create page: 0.146 seconds
