Linuxcnc to USB controller
- Rørbæk
- Thank you received: 7
28 Sep 2020 10:25 #184129
by Rørbæk
Linuxcnc to USB controller was created by Rørbæk
I have been surching your forum for how to use Linuxcnc on a newly bougth cnc6040 with usb controller i can only find something from
2014 where is was not possible has that changed
- Thank you received: 2175
28 Sep 2020 10:28 #184131
Replied by cmorley on topic Linuxcnc to USB controller
no USB motion control with linuxcnc.
- Thank you received: 4144
28 Sep 2020 10:28 #184132
Replied by rodw on topic Linuxcnc to USB controller
No, the linuxcnc design precludes the use of USB because the link is not guaranteed to be real time and has latency built in by design.
- BeagleBrainz
- Visitor
28 Sep 2020 10:34 #184134
by BeagleBrainz
Replied by BeagleBrainz on topic Linuxcnc to USB controller
USB is still not a possibility.
Even if it was some one would have to write a driver your particular USB controller.
The thing is with USB cnc controllers is that they do the motion control, where as Linuxcnc is the motion controller.
- Thank you received: 7468
28 Sep 2020 11:51 #184141
Replied by tommylight on topic Linuxcnc to USB controller
Forum use DaBit has made that work to a certain extent a while back, he did manage to control an arduino from LinuxCNC via USB, but i am not aware that he did continue that work.
The following user(s) said Thank You: Rørbæk
- Rørbæk
28 Sep 2020 18:00 #184190
by Rørbæk
Replied by Rørbæk on topic Linuxcnc to USB controller
Thank for your replay so quickly
28 Sep 2020 21:03 #184215
You are welcomed, always.
Did you manage to find the topic in this forum about it?
I could not find it after some 5 minutes of searching.
- Rørbæk
29 Sep 2020 18:32 #184319
by Rørbæk
I only found something from 2014 so i have serch for a CPU with a 32 bit system and use the mach 3 program following the cnc machine and i will be back ti your gays and report my findings thank you
