Editing Path Blending
- Aldenflorio
- Thank you received: 15
30 Sep 2020 06:55 #184357
by Aldenflorio
Editing Path Blending was created by Aldenflorio
I read that G64 P0.005 will essentially remove path blending (as in it makes the tolerance of what the tool path can deviate from the actual gcode 0.005 of a inch) am I able to use the custom actions tab of the configuration tab on dxf2gcode so that it will automatically set G64 to this?
- Aldenflorio
30 Sep 2020 17:12 #184395
by Aldenflorio
Replied by Aldenflorio on topic Editing Path Blending
Never mind
Time to create page: 0.063 seconds
