Machine units=inches-Lead screw=metric
- kfashby2020
30 Sep 2020 20:55 #184421
by kfashby2020
Machine units=inches-Lead screw=metric was created by kfashby2020
Hello from Dixie to all you Linux guru's. Newbie here doing a CNC mini lathe conversion with a question. Looking over LinuxCNC as a control software in the "Base Information" machine units would be inches, as that is what I'm familiar with. Further down the config screen under "Axis X (Y) the "Lead Screw Pitch" is set for inches/rev. Searching for upgrading my lead screws to Ball Screws, most of which are metric. Hence my question, can I do the metric to inch conversion for the Lead Screw Pitch entry. Example: 5mm ball screw, 1 start = .196850 inches/rev = 5.08 rev/inch.
Note: As I stated i am a newbie to the CNC word and Linux, but been a machinist for many moons. All help is great is greatly appreciated and thanks for having me.
kim
kim
- Thank you received: 4653
30 Sep 2020 22:40 #184431
Replied by andypugh on topic Machine units=inches-Lead screw=metric
Yes, no problem at all.
It's all just numbers to the computer.
- kfashby2020
30 Sep 2020 22:53 #184433
by kfashby2020
Replied by kfashby2020 on topic Machine units=inches-Lead screw=metric
Thanks Andy. Do my figures look correct? How many decimal point will Linux let you enter in the lead screw field. My reasoning is the more decimal points, the more accurate the result.
Again, thanks for the reply and the help.
30 Sep 2020 23:02 #184435
LinuxCNC uses double-precision, so that's about 15 significant digits.
Inside the travel of a typical machine you don't need that. You can stop at one atomic radius
Your numbers are correct for the config wizard. But you could consider editing the INI file afterwards where the input data will have been converted to steps-per-inch and a more-round number might be possible. For example a 5mm screw and a 200 steps-per-rev motor at 8x microstepping is exactly 8128 steps per inch.
- kfashby2020
01 Oct 2020 00:18 #184438
by kfashby2020
Andy, thanks again. For us new guys it really means a lot to have someone with knowledge help lead the way.The only problem is I was really shooting for that A-tomic radius. Oh well, maybe not such a good idea for a 7X10 import lathe.
As for the INI file, what would be the purpose of changing that. Newbie question I know, this is really all new to me. Are you saying that after entering my conversion number for the lead screw, to check the INI file and adjust the the steps-per-inch to match the true number?
Or am I missing something here?
- arvidb
- Thank you received: 158
01 Oct 2020 00:58 #184439
by arvidb
According to Wikipedia, the radius of an aluminium atom is about 125 pm, or 0.000000005 inch.
For a 0.5 m long axis, that's one part if 4 billion, so you'd need 10 decimal places to get the required precision. Obviously I'm very relieved that LinuxCNC has the precision required to handle this.
Replied by arvidb on topic Machine units=inches-Lead screw=metric
I got curious about how many decimal places is required to reach that atomic radius.LinuxCNC uses double-precision, so that's about 15 significant digits.
- BeagleBrainz
- Visitor
01 Oct 2020 01:15 #184440
by BeagleBrainz
Replied by BeagleBrainz on topic Machine units=inches-Lead screw=metric
Can Linuxcnc calculate probability & wave functions ? Atoms aren't quite close enough for me.
- Thank you received: 4146
01 Oct 2020 08:53 #184464
I'm glad to be using metric units I think. I am happy with microns so milimetres to 3 decimals is enough for me
Replied by rodw on topic Machine units=inches-Lead screw=metric
- BeagleBrainz
- Visitor
01 Oct 2020 09:09 #184466
by BeagleBrainz
Yeah but you're using fire
Anything hot & bright = fire
01 Oct 2020 09:24 #184470
The number you calculated should come out as a round(ish) number of steps-per-inch as there are a round number of steps-per-rev and and only one significant decimal digit in mm-per-inch. But the reciprocal is very long: 1 inch = 25.4mm but 1mm = 0.039370078740157480314960629921259842519685039370079... inch.
So, the number that you need to enter in the config wizard is very long, but should resolve to a shorter and more exact number in the INI.
Time to create page: 0.474 seconds
