Missing first 5 pulses on direction change
  • oddwick
  • oddwick's Avatar Topic Author
  • Premium Member
  • Premium Member
05 Oct 2020 16:32 #184983 by oddwick
Replied by oddwick on topic Missing first 5 pulses on direction change
ok after changing my timing numbers, that seemed to fix the problem. that is just weird that it only manifest on the x axis like that and i have another controller that is identical and i was using numbers half that with no problems. now i have following errors that i need to iron out but i can figure that out. thank you everyone for your time and replies!
06 Oct 2020 13:35 #185072 by andypugh
Replied by andypugh on topic Missing first 5 pulses on direction change
The parallel port (and some other controllers) won't necessarily give pulses as short as requested. The 7i96 can do exactly what you ask if you demand a very short step length.
Time to create page: 0.073 seconds
