Proximity Switch wiring
  • wade956
  • wade956's Avatar Topic Author
  • Junior Member
  • Junior Member
02 Oct 2020 18:00 - 02 Oct 2020 18:10 #184597 by wade956
Proximity Switch wiring was created by wade956
Hello everyone, I'm trying to wire the attached switches in for my home switches. I have an input voltage of 5 volts and it appears the output is 2.6 when connected to the 7i96 board.
Brown wire to 5 volts+
Blue wire to -
blk to input.
Last edit: 02 Oct 2020 18:10 by wade956.
02 Oct 2020 18:13 #184600 by Clive S
Replied by Clive S on topic Proximity Switch wiring
Blue wire to -
blk to input.
I think 5 volts might be a bit low for a proximity switch.
The following user(s) said Thank You: wade956
02 Oct 2020 18:16 - 02 Oct 2020 18:18 #184601 by Aciera
Replied by Aciera on topic Proximity Switch wiring
As Clive says try using 24V.
Much better for electromagnetic interference as well.
Inputs of the 7i96 operate with 4V to 36V DC
Last edit: 02 Oct 2020 18:18 by Aciera.
02 Oct 2020 19:17 #184605 by PCW
Replied by PCW on topic Proximity Switch wiring
+2.6V open circuit is about right if the 7I96 input common is at +5V
(7I96 input common must be at + voltage to use NPN sensors)
02 Oct 2020 19:29 #184606 by Mud
Replied by Mud on topic Proximity Switch wiring
Would PNP sensors be more noise resistant? I used NPNs on my 7i96 since I had them already, but did wonder.
02 Oct 2020 20:52 #184620 by PCW
I don't think it makes much difference noise immunity wise.
With 7I96 inputs you can accommodate either type
but since there is a single common all inputs must
be the same so for example if you use NPN proximity
switches, all inputs will be sourcing (ground to activate)
The following user(s) said Thank You: Mud
  • wade956
  • Junior Member
  • Junior Member
02 Oct 2020 22:50 - 02 Oct 2020 22:51 #184642 by wade956
Replied by wade956 on topic Proximity Switch wiring
Thanks - put 24 volts to the inputs and it works. Awesome forum. So much help. :)
Last edit: 02 Oct 2020 22:51 by wade956.
