Quick Question need some Guidance !!
03 Oct 2020 10:20 #184673 by ROD
I am a totally new to cnc. I purchased a drill/mill that has been converted etc.... it utilizes a smooth stepper can I still use Linux cnc or am I restricted to using it with Mach3/4. I have the Mach 4 demo installed and can jog the machine around but that's as far as I have forgotten. Thought I would check to see if linuxcnc was an option before laying out the cash for Mach4.
  • BeagleBrainz
  • BeagleBrainz's Avatar
  • Visitor
  • Visitor
03 Oct 2020 10:30 - 03 Oct 2020 10:33 #184675 by BeagleBrainz
Replied by BeagleBrainz on topic Quick Question need some Guidance !!
Sorry mate, but you're stuck with Mach3/4.
A bit of tech:
www.machsupport.com/forum/index.php?topic=22821.0
Last edit: 03 Oct 2020 10:33 by BeagleBrainz.
03 Oct 2020 10:40 #184676 by ROD
Replied by ROD on topic Quick Question need some Guidance !!
Thanks that is what I was afraid of.
  • BeagleBrainz
  • Visitor
  • Visitor
03 Oct 2020 10:50 #184677 by BeagleBrainz
A Mesa card, which works with Linuxcnc, costs about the same as a Mach4 Licence.
If you are so inclined you could convert to Linuxcnc\MESA and maybe recoupe some of the cost by selling the Smooth stepper one.
You'll get plenty of help.
Come to the Darkside, we have Realtime & Cookies. :)
04 Oct 2020 10:11 #184794 by ROD
Part Two and please pardon my lack of knowledge here. My current setup also contains a Gecko G540 can this be directly controlled from the PC if I load Linux cnc on one that has a native parallel port on it ?
Current setup is as follows,, PC/Mach4 Demo >Ethernet port and cable > Ethernet Smoothe Stepper> Gecko G540 > out to motors.
Setup In question? Linuxcnc >out parallel port via cable to > Gecko G540> Out to motors.
04 Oct 2020 10:12 - 04 Oct 2020 10:14 #184795 by ROD
Double post sorry about that.
Last edit: 04 Oct 2020 10:14 by ROD. Reason: Double post
  • BeagleBrainz
  • Visitor
  • Visitor
04 Oct 2020 10:23 #184797 by BeagleBrainz
Yep
  • Moderator
  • Moderator
04 Oct 2020 11:03 #184799 by tommylight
Replied by tommylight on topic Quick Question need some Guidance !!
Yes.
The following user(s) said Thank You: ROD
05 Oct 2020 00:03 #184886 by ROD
Thanks everyone Im going to give the Darkside a go !!!
  • BeagleBrainz
  • Visitor
  • Visitor
05 Oct 2020 00:20 #184888 by BeagleBrainz
Enjoy :cheer:
Time to create page: 0.152 seconds
