7i76e Connection refused LinuxCNC 2.8
04 Oct 2020 21:18 - 04 Oct 2020 21:20 #184872 by Mtndrew77
7i76e Connection refused LinuxCNC 2.8 was created by Mtndrew77
My old CNC computer had a motherboard failure so I recently upgraded to LinucCNC 2.8. Now I'm having connections issues with my new computer and 7i76e Mesa. Attached is The Linuxcnc.report. Has anyone else had a similar issue?
Last edit: 04 Oct 2020 21:20 by Mtndrew77.
  • BeagleBrainz
  • BeagleBrainz's Avatar
  • Visitor
  • Visitor
04 Oct 2020 21:29 - 04 Oct 2020 21:37 #184873 by BeagleBrainz
Replied by BeagleBrainz on topic 7i76e Connection refused LinuxCNC 2.8
Your attachment failed to attach.
Could you give a bit more info regarding your machine & os ?
Can you describe the issue with a bit more detail.
Have you searched the forum, and there plenty of topics, with issues similar to yours ?
How have you setup your NIC for your MESA card ?
Last edit: 04 Oct 2020 21:37 by BeagleBrainz.
05 Oct 2020 01:21 #184901 by Mtndrew77
Replied by Mtndrew77 on topic 7i76e Connection refused LinuxCNC 2.8
Okay the file should be attached now. The file extension out of linuxcnc is .report and needed to be renamed .txt.
The Mesa card is setup with address 192.168.1.121 and I am able to ping it and get a response. I'm running on a Asus Chromebox with LinuxCNC 2.8 buster installed from the ISO image from the download section. Below is the error I'm getting and the file should attach this time
Debug file information:
Note: Using POSIX realtime
iptables: Bad rule (does a matching rule exist in that chain?).
hm2_eth: rtapi_app_main: Connection refused (-111)
./BRIDGEPORT.hal:9: waitpid failed /usr/bin/rtapi_app hm2_eth
./BRIDGEPORT.hal:9: /usr/bin/rtapi_app exited without becoming ready
./BRIDGEPORT.hal:9: insmod for hm2_eth failed, returned -1
File Name: linuxcnc2.txt
File Size:5 KB
05 Oct 2020 01:32 #184902 by PCW
Replied by PCW on topic 7i76e Connection refused LinuxCNC 2.8
What does the command:
ip a
report?
05 Oct 2020 02:00 #184912 by Mtndrew77
Attached is what I get.
File Name: ip_a.txt
File Size:1 KB
File Name: ip_a.txt
File Size:1 KB
05 Oct 2020 02:02 #184913 by Mtndrew77
Same file I just accidentally attached it twice
05 Oct 2020 02:23 #184917 by PCW
You have your host IP address set to the 7I76E's address
(try say 192.168.1.100)
05 Oct 2020 21:41 #185009 by Mtndrew77
Yep! that was the problem. Back up and running now.
Many thanks!
Time to create page: 0.099 seconds
