Codes for external buttons
- raychar
05 Oct 2020 04:32 #184923
by raychar
Codes for external buttons was created by raychar
Hello guys,
Wanting to implement the following individual hardware external buttons for:
> jogging X+, X-,Y+ ....A+ and A- axis
> jog speeds increase and decrease
> cutting feed override increase and decrease
Thinking that the 2 and 3 items need graphical sliders on the display for the indication, but I haven't yet open the Pyvcp or else on my current version is 2.8. i think i need to do so.
Are those codes available or some advice to code them available? Thanks in advance.
- Thank you received: 2181
05 Oct 2020 05:31 #184925
Replied by cmorley on topic Codes for external buttons
What screen are you wanting this to display on?
- raychar
05 Oct 2020 07:07 #184938
by raychar
Replied by raychar on topic Codes for external buttons
Axis gui.
06 Oct 2020 11:32 #185051
Replied by andypugh on topic Codes for external buttons
The Axis GUI already echoes feed and speed overrides from external controls.
For example if you connect a button to halui.feed-override.decrease every time you press the button the slider in Axis will move. (by 1/halui.feed-override.scale)
If you prefer to use an MPG, use the halui.feed-override.counts pin instead, connected to the MPG counts. You also need to enable halui.feed-override.count-enable for the MPG to work. Either by an enable switch or a "setp halui.feed-override.count-enable 1" in the HAL file.
- raychar
07 Oct 2020 14:21 #185254
by raychar
"For example if you connect a button to halui.feed-override.decrease every time you press the button the slider in Axis will move. (by 1/halui.feed-override.scale)"
I did this, thanks. BTW, when I press the button continuously, is it possible to make the slider decrease continuously as well?. Currently, it is.. one click one step increases
- BeagleBrainz
- Visitor
07 Oct 2020 14:56 #185256
by BeagleBrainz
Replied by BeagleBrainz on topic Codes for external buttons
I don’t think so. Could be possible with a custom Hal comp.
Actually that could be useful, if one doesn’t already exist.
Hopefully one of Devs might have an idea.
- AgentWD40
- Thank you received: 96
07 Oct 2020 15:06 #185258
by AgentWD40
This behavior could also be useful on some touch screen controls.
Replied by AgentWD40 on topic Codes for external buttons
07 Oct 2020 15:16 - 12 Oct 2020 11:57 #185259
All things are possible. But that isn't a built-in behaviour.
A quick and dirty way to do that would be to " and2 " the button with a " siggen " clock signal. But that would be a bit wierd to use depending on when in the cycle you pressed the button.
Better would be a custom HAL component something like this (note that I am typing this in a break at work on a windows PC, so it is from memory and untested)
component autorepeat "auto-repeat a button press";
pin in bit in "input signal";
pin out bit out "output";
pin in float hold "hold time";
pin in float repeat "repeat time";
license "gpl2+";
author "andypugh";
static int stage = 0;
static double timer;
if (in == 0){
out = 0;
stage = 0;
switch(stage){
case 0: // idle
out = in;
if (in) {
stage = 1;
timer = 0;
case 1: // timing hold
timer += fperiod;
if (timer > hold){
out = 0;
stage = 2;
timer = 0;
break;
case 2; // toggling
timer += fperiod;
if (timer > repeat){
out = 1;
stage = 3;
timer = 0;
break;
case 3; // toggling 2
timer += fperiod;
out = 0;
stage = 2;
timer = 0;
break;
Last edit: 12 Oct 2020 11:57 by andypugh. Reason: Moved the test for in==0 out of the state machine for simplicity
The following user(s) said Thank You: BeagleBrainz
- raychar
12 Oct 2020 13:07 #185830
by raychar
Where and how to put this C program into Linuxcnc?
12 Oct 2020 13:12 - 12 Oct 2020 13:13 #185831
It isn't normal C, it is the ".comp" component definition language. (Which used C for the actual code section).
If you follow the link in the post you should find the halcompile documentation.
But, summary
Save the code in a file called "autorepeat.comp"
compile and install with "sudo halcompile --install autorepeat.comp"
(debug until it compiles cleanly)
Then load into the HAL file with "loadrt autorepeat count=4" to get 4 of them.
But, summary
Last edit: 12 Oct 2020 13:13 by andypugh.
Time to create page: 0.329 seconds
