- Thank you received: 26
Wicd Network Manager with Mesa Ethernet cards
- jtrantow
6 years 3 weeks ago #184985
by jtrantow
Wicd Network Manager with Mesa Ethernet cards was created by jtrantow
I just updated to the buster LinuxCNC 2.8 iso which uses the Wicd Network Manager.
The sticky at forum.linuxcnc.org/27-driver-boards/3559...t-mesa-boards#121458 uses the Network Manager and not wicd.
I am trying to simultaneously connect a Mesa 7i92 to the motherboard ethernet and the wifi to the internet. I can set up and successfully switch between the direct and wireless interfaces. But I can't figure out how to simultaneously use both interfaces.
Do I need to uninstall wicd and install the Network Manager to get this to work?
I tried connecting to wifi with wicd and using ip link set dev mydirectconnectdevicename up but that didn't work either.
I've used ifconfig to get multiple interfaces working on other installs, but wicd and ip are new to me. Is there a supported way to get both interfaces to work?
- jtrantow
6 years 3 weeks ago #184986
by jtrantow
Replied by jtrantow on topic Wicd Network Manager with Mesa Ethernet cards
From #182754
apt-get install network-manager network-manager-gnome
apt-get remove wicd wicd-gtk
Wifi and direct connect to mesa now work simultaneously. Suggest adding this step to #121458
- Thank you received: 7491
6 years 3 weeks ago #185008
Thank you.
Replied by tommylight on topic Wicd Network Manager with Mesa Ethernet cards
Done.jtrantow wrote: From #182754
Thank you.
- JackW327
- Thank you received: 14
5 years 4 months ago #213047
by JackW327
Replied by JackW327 on topic Wicd Network Manager with Mesa Ethernet cards
Worth mentioning perhaps. Wicd did not initially let go for me. My hack at this was:
>> Reboot
>> apt-get remove wicd wicd-gtk again (under sudo)
>> Reboot
>> service NetworkManager restart (under sudo)
Then re-setup the WiFi & follow the instructions in post #121458 linked to in the OP. Now I can ping my 7i95 at 10.10.10.10. Moving on ...
Shortly after I did the second remove the icon in the task bar changed so I believe netman took over at that point. After the 1st reboot, before the 2nd remove, Wicd was still present in the Xfce Internet menu and it was still managing the connections.
A little hacking may be required is all. Kind of expected when two stacks of software are trading the same physical resources.
>> Reboot
>> Reboot
Time to create page: 0.837 seconds
