Tandem y axis for plasma table
- Electechcans
- Topic Author
60 IPs is about the limit (100 KHz)
If you want 200 IPS, that's 324 KHz so about 1500/1500 max steplength/stepspace
Electechcans wrote: I setup the motors using the tuning tool in pncconf and I was moving 1 inch, 2 inches, 3 inches, and so on. If i told that joint to move 1 inch it moved 1 inch, if i told it to move 2 inches it moved 2 inches i adjusted the scaling until it was correct in the tuning tool in pncconf. Why when i go to use Linuxcnc is it any different if i already had the motors tuned in pncconf? It moves roughly 10 inches in linuxcnc when i tell it to move 1 inch, using the same setup from pncconf. Am i missing something?
I'm not sure what pncconf does with its calibration numbers but it may expect you to enter the
value you determine into the scale field
- Electechcans
- Topic Author
calibrate menu (and its save to file option) or hand editing the ini file. That should allow you to finalize the scale setting, step timings and joint velocity and acceleration values (the latter 2 require editing the ini file)
- Electechcans
- Topic Author
