Thermal dynamics cutmaster 82 and mesa THC
- Craft4539
06 Oct 2020 22:40 #185155
by Craft4539
Thermal dynamics cutmaster 82 and mesa THC was created by Craft4539
hello all,
I have a cutmaster 82 that I purchased new in 2009 which I would like to use as the power source for a plasma table. This unit does not have the CNC interface but one is available from the manufacturer, their is a pin terminal on the wiring diagram J10 that makes the the below data available along with raw arc voltage. Does using the Mesa THC delete the need for the 9-8311 TD machine interface that gives a 50:1divided voltage output.
Arc ok
Start
+12 volts
Arc ok
Start
+12 volts
- Thank you received: 5321
06 Oct 2020 23:38 #185166
Replied by PCW on topic Thermal dynamics cutmaster 82 and mesa THC
Can you get the interface with the divider?
This is safer as it involves no high voltage wiring
- Craft4539
07 Oct 2020 01:53 #185177
by Craft4539
Replied by Craft4539 on topic Thermal dynamics cutmaster 82 and mesa THC
yes, but if the Mesa THC would work I could apply the funds towards linear rails.
Just trying to place funds in the best places.
07 Oct 2020 02:27 #185181
The THCAD-300 should work (it can connect directly to the plasma voltage) but requires careful wiring to avoid multiple electrical hazards
- Thank you received: 4144
07 Oct 2020 10:13 #185223
Replied by rodw on topic Thermal dynamics cutmaster 82 and mesa THC
I have the Thermal Dynamics A120 plasma cutter. The A says it came as standard with the automation interface.
I would buy the interface, set it to 30:1 and use a THCAD-10 with no scaling resistor (full scale 300 volts)
This is how I have my machine set up and it works well.
The divider gives a very clean signal and you get a real ArcOK so you end up with a better, more robust, more reliable machine. I know people will tell you its not necessary, but really, you have enough challenges in front of you building a machine without adding some more possible problems!
Ultimately, if you don't already have it, factor in a SL100 machine torch. That will make your eyes water a lot more than the automation interface!
- Craft4539
07 Oct 2020 12:46 #185240
by Craft4539
Thanks Rod, I've read your entire build string , I've been watching ebay for the automation card and the machine torch. I appreciate your guidance as I don't want to purchase unnecessary items.
