PlasmaC Z axis setup
07 Oct 2020 17:50 #185285 by Electechcans
PlasmaC Z axis setup was created by Electechcans
I am looking for info on how to config my z axis for my plasma table. I have PlasmaC setup and when i try to home it drives down into the table and ignores my float switch, i also think i have my home switch set wrong. I have a limit switch set about 2.5 inches above the table on my z axis that is set as home. This is wired as input 7 on my mesa card, i have my float switch setup as input 8 on my mesa card. I just want it to run to my upper limit input 7 when i home and then when it starts to run the program in position then go to the float poistion. Is this incorrect? If not how do i set this up? I have included my updated ini and hal files. Thanks for any help.
File Name: tdcindustr...asma.hal
File Size:11 KB
File Name: tdcindustr...asma.ini
File Size:10 KB
07 Oct 2020 22:11 #185306 by phillc54
Replied by phillc54 on topic PlasmaC Z axis setup
Z axes are more negative moving down, so your HOME and HOME_OFFSET should be around 3.00, depending on the relationship of your home switch to your MAX_LIMIT. Your MIN_LIMIT should be below the top of the slats.
Also make sure that when you press the button to jog Z in the minus direction it does move down.
Time to create page: 0.143 seconds
