Why FF1 has no effect in LinuxCNC v2.7.15 ?
- HalaszAttila
- Thank you received: 5
13 Oct 2020 07:16 - 13 Oct 2020 07:43 #185930
by HalaszAttila
Why FF1 has no effect in LinuxCNC v2.7.15 ? was created by HalaszAttila
Hello,
i make retrofit many machines with analog servos in the past with linuxcnc v2.7.15.
And was not clear why FF1 has no action when u tune the PID. I remember, in the past with other versions of linuxcnc i can use FF1, and it is radically lower the following error in the change of direction of motor, and i really like it.
Now i tested it a little.
I made a new 3axis config with pncconf with v2.7.14 for mesa 5i25 + 7i77. Connect a sanyo denki servo with +/-10V velocity mode and try to tune the PID. In the scope i see the effect of FF1.
But, when i start the same config with v2.7.15, the FF1 has absolutly no effect.
I use this ISO:http://www.linuxcnc.org/iso/linuxcnc-2.7.14-wheezy.iso
And the newer (2.7.15) version is compiled from source.
Can someone help me why FF1 not works in 2.7.15?
And what is the solution?
Has anyone encountered this problem yet? 2.7.15 is released in January this year.
Thanks.
Thanks.
Last edit: 13 Oct 2020 07:43 by HalaszAttila.
- HalaszAttila
13 Oct 2020 09:49 #185952
by HalaszAttila
Replied by HalaszAttila on topic Why FF1 has no effect in LinuxCNC v2.7.15 ?
I attached a screenshot of difference between PID component from 2.7.14 and 2.7.15 versions. This is the only difference.
I compiled 2.7.15 with pid.c component from 2.7.14 and now i have working FF1 parameter in pid when i running LinuxCNC 2.7.15.
Please check this problem, maybe it woluld be good to solve in newer versions.
- Thank you received: 1476
13 Oct 2020 13:22 #185979
Replied by Todd Zuercher on topic Why FF1 has no effect in LinuxCNC v2.7.15 ?
Could you share your hal file? There was a longstanding bug found in the PID that was fixed about then. But fixing the bug had the result that connecting things that shouldn't be in the hal file, can cause the results you describe.
Do you have anything connected to the PIDs pins "pid.N.command-deriv"
The following user(s) said Thank You: HalaszAttila
- HalaszAttila
13 Oct 2020 14:12 #185984
by HalaszAttila
I answer with phone, therefore cant attach the hal file now. I am beside machine. Tonight i can attach the file.
But the pid.N.command deriv not connected with other signal.
Here is the line from hal.
net x-vel-cmd pid.x.command-deriv
But x-vel-cmd signal has no source.
What to do to use FF1?
- Thank you received: 5326
13 Oct 2020 16:05 #185997
Replied by PCW on topic Why FF1 has no effect in LinuxCNC v2.7.15 ?
comment out or delete:
and FF1 will work
and FF1 will work
13 Oct 2020 16:21 #185998
The PID comp can only detect if its pid.N.command-deriv is connected to a signal. It can't tell if that signal is receiving anything. By having it connected to an unused signal it disables the FF1. Like Peter said, comment out or delete that line and FF1 function will be restored by calculating the velocity command internally. Alternatively connect that signal to a valid velocity command, But there may be some issues with using the one from motion.
- HalaszAttila
14 Oct 2020 06:20 - 14 Oct 2020 06:21 #186071
by HalaszAttila
Thanks for quick answers. I deleted a net x-vel-cmd pid.x.command-deriv line and FF1 works.
Last edit: 14 Oct 2020 06:21 by HalaszAttila.
Time to create page: 0.538 seconds
