Lathe router machine? XYA
- nemoskullalt
16 Oct 2020 21:49 #186318
by nemoskullalt
Lathe router machine? XYA was created by nemoskullalt
im trying to build a lathe with a router instead of a cutting tool. can linuxcnc do this? XY movment, with a rotational axis on the chuck. im kinda lost here. thanks.
- Thank you received: 7468
16 Oct 2020 22:36 #186327
Replied by tommylight on topic Lathe router machine? XYA
That would be a normal XZ lathe, and since LinuxCNC can control more than one spindle, you can have both of them controlled by it.
- Thank you received: 2164
17 Oct 2020 07:17 #186345
Replied by Aciera on topic Lathe router machine? XYA
So would the A be a spindle or an axis or both? Because if it is an axis only then you would have a XZA mill where the y axis is wound around the A.
- nemoskullalt
17 Oct 2020 11:50 #186349
by nemoskullalt
Replied by nemoskullalt on topic Lathe router machine? XYA
so linuxcnc can use the spindle as a servo/stepper, as in DIR and STEP controlled?
- nemoskullalt
17 Oct 2020 11:51 #186350
by nemoskullalt
A axis would be the chuck, the router is simple one and off.
17 Oct 2020 15:34 #186367
If A only needs to be rotated as an axis (low speed for milling with the router) then its simply a rotational axis. The router would be your spindle and your machine would be run with a mill configuration. Like this but without the Y-Axis
If the chuck also needs to rotate at high speeds like a lathe then you will need a larger servo motor (as a stepper motor would be too slow) and your chuck would be a second spindle. But this does not really make much sense when using a router.
Both setups can be controlled using Step/Dir .
The following user(s) said Thank You: nemoskullalt
- nemoskullalt
18 Oct 2020 13:51 #186462
by nemoskullalt
thank you, this is what i as looking for.
