Adding users to LinuxCNC
- Slartidad
16 Oct 2020 21:54 #186320
by Slartidad
Adding users to LinuxCNC was created by Slartidad
First: I'm sorry to ask such a basic question.
I cannot get LinuxCNC to accept adduser or useradd command to work. Is there a tutorial for the tragically unenlightened?
I have a home built CNC using LinuxCNC for about a year, working AWESOME BTW, but have now added a fourth axis and due to the limitations of my software (Vectric Desktop) must change ini file each time I change from XYZ to XAZ. My idea is to have two different logins, one for XYZ and one for the rotary setup. Each Login would use a different setup.
1. Is this a workable idea?
2. Is there a better idea?
3. Why do I smell burning brain cells?
- Thank you received: 7488
16 Oct 2020 22:33 #186326
Replied by tommylight on topic Adding users to LinuxCNC
Yes, make two configs and start the one you need as you need at any given time. No reboots, no logouts.2. Is there a better idea?
I smell that here, too !3. Why do I smell burning brain cells?
- JohnnyCNC
- Thank you received: 115
16 Oct 2020 23:36 #186333
by JohnnyCNC
Replied by JohnnyCNC on topic Adding users to LinuxCNC
I did as tommylight said to handle two different configurations of my mill. I have two spindles. The standard one and a highspeed 24K spindle. I will never use both at the same time. I just made a copy of my config directory under another name and changed the new config as needed. I also renamed the .ini & .hal in the new directory just for my own sanity.
I have two shortcuts on my desktop, one for each machine. Very easy to run either configuration.
\linuxcnc\configs\SiegX3
\linuxcnc\configs\SiegX3HS
- BeagleBrainz
- Visitor
17 Oct 2020 00:11 #186334
by BeagleBrainz
Replied by BeagleBrainz on topic Adding users to LinuxCNC
Unfortunately my psychic powers were traded for some magic beans, so I can't work out how you were using the command or what error messages you are getting. Are you trying to create a user without using sudo ?
Time to create page: 0.092 seconds
