hello everyone, I am working on a hurco km3 retrofit and am having trouble figuring out the end stock switches. I have found the wires that are an active +5v normally and when tripped go to 0v. But when looking through the 7i77 documents it looks like the field power sets the threshold for the inputs. So am I correct to think that to get the mesa card to register the end stop input it would need to read a high signal something like +14v? And it looks like to read a low it needs to be something like +8v but not zero? If this is correct how do I wire that up? I did get a pack of opto isolators thinking I will have to use those. I will add a video of what I am working on hopefully shedding some light on what I am trying to do and the problems I am having.
Sorry if these are dumb questions, I am figuring this all out as I go. Thanks for any help you guys can give!
