How to wire 5v end stops into 7i77 input
6 years 2 weeks ago #186358 by Chungus
Yes but the motor is only disengaged in that direction. So let’s say it’s homing in the x+ direction when it hits the switch it only allows x- travel so you can’t further over travel the machine
6 years 2 weeks ago #186360 by Mike_Eitel
That is what i partialy expected. But that also means that you have some kind of 'intelligence' between your driver and lcnc. Is that without further conflicts? Does it beside of that reacts stupid simple on step/dir signaling?
Mike
6 years 2 weeks ago #186361 by PCW
As Mike_Eitel mentioned you may have LinuxCNC's and the drives homing system fighting
(you lose full closed loop motion control as soon as you hit the limit since full control requires drive in both directions during decelerarion)
That said, if you have any free encoder inputs, these can be used for 5V signal sensing
if set into TTL mode.
6 years 2 weeks ago #186362 by Chungus
The only connection between my driver and lcnc I have is the analog signal to the driver to give velocity/direction. Here is a link to the driver pdf that I have.
www.scribd.com/document/52328054/Electro...e-Instruction-Manual
So I have no conflicts with lcnc communicating with the driver.
6 years 2 weeks ago #186363 by Chungus
PCW that makes sense. I will play around with it today and see if I can get that to work
6 years 2 weeks ago #186364 by PCW
You do have a conflict, because with a velocity mode servo, LinuxCNC
expects to control deceleration after the limit switch is hit, but if velocity
commands in the direction of the limits are disabled after the limit is hit
linuxCNC not longer has this control and the axis will simply coast to a stop
Time to create page: 0.078 seconds
