Mesa 7I96 Proximity sensor PNP or NPN?
  • Xyetti
  • Xyetti's Avatar Topic Author
  • New Member
  • New Member
18 Oct 2020 22:29 #186524 by Xyetti
Hello, I am lookingat purchasing a IFM Inductive Sensor at an auction. Can I use this 10...36 Volt DC PNP with the Mesa PWB.
Also is the 10 volt -36 volt to much as I hear people using 5 V induction sensors.
18 Oct 2020 22:41 #186528 by rodw
Replied by rodw on topic Mesa 7I96 Proximity sensor PNP or NPN?
yes, usually you wan to use 24 volts for field power and inputs.
The 7i96 can handle PNP or NPN sensors depending on if you connect +24v or -24v to the input common
7i76e et all prefer PNP anyway!
The following user(s) said Thank You: Xyetti
19 Oct 2020 23:14 #186632 by grijalvap
Replied by grijalvap on topic Mesa 7I96 Proximity sensor PNP or NPN?
It is a good Idea always using Normally closed and change the logic as required, this can help to deal with noise environments.
Time to create page: 0.135 seconds
