Suggestions for debugging?
- quarklark
My shop recently got a Precix Mesa CNC mill running, and I ran into these errors while running a test job:
The job was running just fine until the machine halted, but the computer seemed to think that it was still running. I've not been able to reliably replicate the issue, but it has happened three times. Twice, it halted about an hour into a long drag engrave job, and once it halted while jogging the machine after restarting from the previous crash.
Any suggestions on what to investigate? Or how to replicate the issue?
Our machine uses a Mesa PCI card with the 7i76 Daughter Card. I'm currently working on collecting the configuration files and more details on the machine itself. (Let me know if anything would be particularly helpful.)
I'm personally new to linuxcnc, and just learning the details of our machine. and any pointers would be greatly appreciated!
Thanks!
- Thank you received: 5326
Possible causes include:
Cabling problems between the 7I76 and the 5I25
Loss of 5V at the 7I76
Loss of field power at the 7I76
- quarklark
I'm surprised there's no feedback from the 7I76 to the 5I25, and the program kept running. Is there a way to have linuxcnc pause the program if communication is interrupted? (Rather than continuing on?)
Regarding cabling, we were thinking that our cable run may be a bit too long, and that noise may be a factor. Were you thinking along those lines, or just general damage / connection issues?
To determine if we're loosing power at the 7I76, I guess it's the sort of thing that we'll need to encounter the problem again, then probe to see if power is where we'd expect it to be?
Also, does linuxcnc have a centralized logging system? I happened to take that picture of the errors, but I imagine it would be much easier to look at a log file to see what's going on.
Thanks for the quick reply!
There is feedback but you would need to connect it in hal:
hm2_5i25.0.sserial.port-0.run
reports the status of the sserial port
Noise issues will generally show up as CRC errors. You got a sserial break error
which means a whole character time noise impulse which is very unlikely.
Loss of 5V power at the 7I76 is my best guess as to what happened.
Yes, and check that its OK in normal operation. Marginal supplies or external shorts in say encoder
or stepgen +5V wiring can cause this kind of issue.
For RTAI based systems logging is in the kernel log (view with dmesg).
for Preempt-RT systems the log is dumped to the console device,
so if you start linuxcnc from the command line you can watch the log there,
- quarklark
I'll see if I can hook up the feedback in the HAL, as you mentioned.
- quarklark
However, after re-running the program, I encountered the same machine stop problem but this time there were no errors. It appears as though the 7I76 is still working, but motor stepgen controllers, it seems like they've lost power. I confirmed that 12V is still being supplied to them, and restarting the system brought everything back online.
For reference, I've posted the config files here: github.com/quarklark/GSS-CNC/tree/master/configs
