How to disable screen lock in linuxcnc debian buster
- aleksamc
- Thank you received: 67
20 Oct 2020 12:35 #186714
by aleksamc
How to disable screen lock in linuxcnc debian buster was created by aleksamc
I've installed new linuxcnc 2.8.0 from iso of debian 10 buster.
But there after some time, screen locks and I need to enter password.
In older linux there was configuration for screen savers but here I can't find such thing.
I need to turn off screen lock and auto logout complitly on my nachine.
The following user(s) said Thank You: HalaszAttila
- Grotius
- Thank you received: 2349
20 Oct 2020 13:13 - 20 Oct 2020 13:14 #186719
by Grotius
Replied by Grotius on topic How to disable screen lock in linuxcnc debian buster
Yes i know this. You can do : sudo apt-get install task-xfce-desktop
This will install some things and also the power management tool in : menu->settings->power manager.
An other way is installing a iso wich has already has this power management support and also pre installed linuxcnc + some glade libraries + qtdesigner stuff, so less work around :
github.com/grotius-cnc/LINUX_RTOS/releases/tag/1.0.0
Last edit: 20 Oct 2020 13:14 by Grotius.
The following user(s) said Thank You: aleksamc
- aleksamc
20 Oct 2020 13:40 #186721
by aleksamc
Replied by aleksamc on topic How to disable screen lock in linuxcnc debian buster
thanks a lot, I will try tomorrow.
- Thank you received: 7504
20 Oct 2020 15:06 #186739
Replied by tommylight on topic How to disable screen lock in linuxcnc debian buster
The official Debian release has been updated to have power saving disabled by default, so download the official ISO again if you do not mind reinstalling it, or have a look here for the solution to the existing install
forum.linuxcnc.org/29-forum-announcement...r-iso-file-re-issued
- aleksamc
22 Oct 2020 04:58 #186886
by aleksamc
Yes, it's Work!.
Thanks. My PC is not connected to internet, so it's very nice variant.
- Grotius
22 Oct 2020 12:51 #186913
by Grotius
Hi Aleksamc,
Nice that it works now !
Wich method did you use to get it working?
- aleksamc
23 Oct 2020 00:20 #186972
by aleksamc
At first I think of using your method, but I remembered that PC is not connected to internet. I supposed that look for repository in internet is a little unconvinient from other PC))) So I used method of tommylight.
But as I anderstood later, I should know such terminal commands as rm and touch for removing and creating files, so I think your method would be easier )))
- Adrian Nicol
04 Aug 2021 15:10 #216936
by Adrian Nicol
Replied by Adrian Nicol on topic How to disable screen lock in linuxcnc debian buster
This is a slightly old thread I know but I just downloaded the 2.8.2-11 iso today for a fresh install and it still has the screen lock issue (and the USB/'looking for CD' install issue) I fixed both using the link above pointed to by tommylight for the screen lock and his swapping the USB drive to a new slot when the install grumbles about no media in the CD drive - Thanks tommylight, you saved me a lot of frustration!
Now I suppose I'd better read the manual and figure out how LinuxCNC works!
Adrian
Adrian
05 Aug 2021 04:56 #216956
You are welcomed always, and sorry to burst your moment of joy but there is the 2.8.2 ISO also that has none of those issues and uses network manager instead of WiCD just in case you want to use ethernet for Mesa or Ethercat.
- smal
- Thank you received: 4
05 Aug 2021 06:11 #216963
by smal
Replied by smal on topic How to disable screen lock in linuxcnc debian buster
This worked for me:
Install: xscreensaver with command: sudo apt install xscreensaver
Run application: xscreensaver-demo
then set following: -> Display Modes -> Mode -> Disable Screen Saver
next: Display Power Management -> disable
The following user(s) said Thank You: dokwine
Time to create page: 1.069 seconds
