How to disable screen lock in linuxcnc debian buster
06 Aug 2021 10:44 #217063 by Adrian Nicol
Replied by Adrian Nicol on topic How to disable screen lock in linuxcnc debian buster
That is handy, but where do I find it? The one I had the issue with I downloaded from the download page of linuxcnc.org (linuxcnc-2.8.2-buster.iso) two days ago - on the 4th Aug 2021 - it was shown there as the current release.
Adrian
10 Aug 2021 19:01 #217440 by andypugh
With some hardware you might also need to turn off DPMS.
superuser.com/questions/1218112/how-to-d...screen-off-in-debian
14 Jun 2022 01:00 #245100 by dannym
I found online I wanted to remove the screen locker task from the startup list on xfce. I did that, it doesn't lock the screen now but the screen does go to sleep even with LinuxCNC running (it wasn't running g-code at the time I saw it, though).
Is the best solution still "sudo apt install xscreensaver" and then open it up and disable the screen saver?
15 Jun 2022 06:11 #245183 by andypugh
Screen sleep is generally dpms, like I mentioned above.
Time to create page: 0.240 seconds
