How to close permit to configuration folder
  • aleksamc
  • aleksamc's Avatar Topic Author
  • Platinum Member
  • Platinum Member
20 Oct 2020 17:38 #186715 by aleksamc
I want to create new user "operator" that will not have access to config folder of the machine.
How can I do it? If I close permit to the folder, will linuxcnc work with this folder?
  • Moderator
  • Moderator
20 Oct 2020 20:13 #186741 by tommylight
Replied by tommylight on topic How to close permit to configuration folder
Changing the permissions to the config folder will prevent LinuxCNC from working, but changing the permissions of the HAL and INI files will work just fine. Even tool.tbl can be locked and it will work.
Time to create page: 0.092 seconds
