OUTPUT_MAX_LIMIT and OUTPUT_MIN_LIMIT question
  • aleksamc
  • aleksamc's Avatar Topic Author
  • Platinum Member
  • Platinum Member
22 Oct 2020 08:32 #186882 by aleksamc
I use mesa 7I77 board to operate analog servos.
I set OUTPUT_MAX_LIMIT =2 and OUTPUT_MIN_LIMIT=-2. As I anderstand they limit maximum voltage from output board.
My servos are very fast, they have 3000 rev/min and directly connected to the axe, Their velocity is 5m/sec!
I want to limit their maximum speed even if they will go in unstable state.
So I increase gain parameter P to make my servo unstable. And it became it. When servo become unstable, on the board voltage was not limited by 2V. It was maximum 10V. How can I solve this problem?
22 Oct 2020 14:28 #186900 by cmorley
can you show your config files?
22 Oct 2020 17:31 #186911 by bevins
OUTPUT_SCALE?
22 Oct 2020 18:04 - 22 Oct 2020 18:05 #186917 by PCW
The limits are relative to the output scale
so if output scale is 10, limits of 2 and -2
will limit the output voltage to +-2V
but if the output scale is 1 you would need
limits set to 0.2 and -0.2 to limit the output to +-2V
Last edit: 22 Oct 2020 18:05 by PCW.
  • aleksamc
  • Platinum Member
  • Platinum Member
23 Oct 2020 05:24 - 23 Oct 2020 05:30 #186973 by aleksamc
Replied by aleksamc on topic OUTPUT_MAX_LIMIT and OUTPUT_MIN_LIMIT question
I posted INI file in Oher post . I supposed that for this question is better to create separete thread.
And there Output Scale = 1
MAX_OUTPUT = 0
So I need to change MAX_OUTPUT.
Than what purpose of OUTPUT_MAX_LIMIT?
Last edit: 23 Oct 2020 05:30 by aleksamc.
23 Oct 2020 14:08 #187001 by PCW
If your OUTPUT_SCALE is 1 then you need
OUTPUT_MAX_LIMIT to be 0.2 and
OUTPUT_MIN_LIMIT to be -0.2 to limit the
analog output voltage to +-2V
MAX_OUTPUT probably changes the PID maximum output
but like most INI file values it depends on how they are used in
the hal file
Time to create page: 0.150 seconds
