Inhibit Homing on 2.7
22 Oct 2020 13:15 #186896 by rapht0r
Inhibit Homing on 2.7 was created by rapht0r
Hello dear LinuxCNC Community,
Raphael from Germany here. I have the following question:
The machine (mill) I'm working on has an enclosure with a locking door. So far i figured out how to keep the door locked while anything moves (motion.current-vel or motion.requested-vel are nonzero, the VFD reports a spinning spindle, the motion.spindle-on pin is on, a programm is running by checking halui.program-idle or any of the axes is being homed (axis.N.homing)).
Also opening the door will set motion.feed-inhibit and motion.spindle-inhibit (and motion.feed-hold, though I'm not sure if thats necessary) to "TRUE". I thought that would inhibit any motion, however the homing sequence does not honor the feed-inhibit.
Thus, starting a reference sequence while the door is open is possible. I'd like it to not do the homing sequence while the door is open or unlocked
I noticed that motion 2.8 has a pin motion.homing-inhibit or something rather.
Is a similar functionality also available in 2.7?
Apologies for my bad english and thanks in advance!
Raphael
  • Moderator
  • Moderator
24 Oct 2020 21:15 #187132 by tommylight
Replied by tommylight on topic Inhibit Homing on 2.7
machine-is-enabled
that will inhibit everything and disable the drives, or is there any reason for not using that?
25 Oct 2020 07:52 #187173 by rapht0r
Replied by rapht0r on topic Inhibit Homing on 2.7
Hi, thanks for your reply!
I think i should hive a bit more info about the machine. It's a servo machine and i decided to use the G320X drives. Thus there is no posiotion feedback to LCNC. Also the axis can be pushed around with enough force. As a consequence of those two things i set the VOLATILE_HOME = TRUE in the .ini file. So disabling the drives every time the door is open would also unhome the machine.
I like the idea however..but i dont think i'll be able to to it that way unfortunately.
25 Oct 2020 08:14 - 25 Oct 2020 08:14 #187176 by rodw
Replied by rodw on topic Inhibit Homing on 2.7
probably a more correct method for all your safety features would be to use estop-latch and build an estop chain in hal. Its not documented well but this is possible.
An example.
Warning: Spoiler!
Last edit: 25 Oct 2020 08:14 by rodw.
Time to create page: 0.153 seconds
