Control panel, MUX wiring help
6 years 1 week ago #187023 by lois
Hi there. I've this old bosch panel but no idea how to connect this to MESA7i77. No ideia how to MUX wiring this.
Panel routing layout as follows:
So, looking at this, do i need to use a MUX chips to wire against 7i77? Something like this?
I'm searching some info, pic's or drawings about this subject, to compare and aply, i'm having some dificults here... not so skilled on electronics.
6 years 1 week ago - 6 years 1 week ago #187027 by PCW
Replied by PCW on topic Control panel, MUX wiring help
You could scan that directly from the 7I77 if you can afford to spare
8 outputs and 5 inputs (assuming the schematic is correct and there are no
electronic parts other than the diodes)
Last edit: 6 years 1 week ago by PCW.
The following user(s) said Thank You: lois
6 years 1 week ago #187030 by lois
Replied by lois on topic Control panel, MUX wiring help
Yes, only diodes inside.
I've multimeter checked and each push button is just closing the loop between Scan# and Data#.
Only inputs/outputs i spend were to limit switches and emergency so, free to do this :woohoo:
So, direct wiring 8 outputs(data#) and 5 inputs(scan#) to 7i77? What kind of code do i need to inplement this on hal config?
6 years 1 week ago #187037 by PCW
I was afraid you would ask...
I think the matrix_kb component would do most of the work
but it will be a fair amount of hal plumbing
6 years 1 week ago #187085 by lois
After read some posts about matrix_kb, no chance to me.
Is there any other simplier options to reuse this old panel? Multiple mux components? or just create a sized simplier panel with direct push buttons to inputs?
I don't want all the fancier jigs on this machine, if possible reuse things, if not, keep it simple.
6 years 1 week ago #187088 by rodw
Replied by rodw on topic Control panel, MUX wiring help
Well another solution would be to write your own component that turned those inputs and outputs into meaningful stuff. It would reduce the hal plumbing, but probably not make it much easier if you don't understand C
Time to create page: 0.161 seconds
