Where should one report errors in the documentation
- Thank you received: 2164
28 Oct 2020 08:48 - 28 Oct 2020 08:51 #187529
Where should one report errors in the documentation was created by Aciera
halui.jog has been removed in version 2.8 but there are still references to it in the 2.8 docs as reported here:
forum.linuxcnc.org/24-hal-components/404...ys57e?start=0#187526
However I think it would make more sense to report it somewhere more visible. But where?
Last edit: 28 Oct 2020 08:51 by Aciera.
- BeagleBrainz
- Visitor
28 Oct 2020 08:53 #187531
by BeagleBrainz
Replied by BeagleBrainz on topic Where should one report errors in the documentation
This gives you some options linuxcnc.org/community/
Remember the forum isn't the only source of info regarding Linuxcnc, there is also the main website.
Or you can try the Linuxcnc github
- Thank you received: 4144
28 Oct 2020 09:36 #187535
Replied by rodw on topic Where should one report errors in the documentation
The correct place is on git hub issues register
github.com/LinuxCNC/linuxcnc/issues
I've had a few documentation bugs fixed very quickly that way..
28 Oct 2020 10:14 #187542
Replied by Aciera on topic Where should one report errors in the documentation
I have registered an issue on github.
The following user(s) said Thank You: tommylight, rodw, BeagleBrainz
Time to create page: 0.076 seconds
