Program on lathe stops on random gcode
- Clive S
- Thank you received: 486
31 Oct 2020 14:18 #187911
by Clive S
N20 G96 D3500 S91 M3
N21 G0 Z1.164
N22 X40.
N23 G1 X32.828 you say it stops here but above in line 21 you have a G0 which is modal so this would need a feedrate
N24 X30. Z-0.25
N25 X-0.8
N26 X2.028 Z1.164
N27 G0 X40.
N28 Z0.664
N29 G1 X32.828 The same here when changing from G0 in line 27 to a G1 it needs a feed rate
N30 X30. Z-0.75
N31 X-0.8
N32 X2.028 Z0.664
N33 G0 X40.
N34 Z0.164
N35 G1 X32.828
Just my 2c worth
Replied by Clive S on topic Program on lathe stops on random gcode
The way I see this isYes i've also tried G1 X40. F100
N21 G0 Z1.164
N22 X40.
N24 X30. Z-0.25
N25 X-0.8
N26 X2.028 Z1.164
N27 G0 X40.
N28 Z0.664
N30 X30. Z-0.75
N31 X-0.8
N32 X2.028 Z0.664
N33 G0 X40.
N34 Z0.164
N35 G1 X32.828
Just my 2c worth
- Thank you received: 2164
31 Oct 2020 15:12 #187920
And does it work in MDI mode or not?
Replied by Aciera on topic Program on lathe stops on random gcode
- Anonymous
31 Oct 2020 22:09 #187951
by Anonymous
Replied by Anonymous on topic Program on lathe stops on random gcode
.ini and .hal files
- Thank you received: 5321
01 Nov 2020 03:30 #187974
Replied by PCW on topic Program on lathe stops on random gcode
If you are using G96, I'm pretty sure spindle_at_speed must be true
for G1 to proceed
for G1 to proceed
