Limit/Home switches
- Hippy
05 Nov 2020 20:28 #188442
by Hippy
Limit/Home switches was created by Hippy
Didnt know where else to post this, so before i break out my sledgehammer and destroy all my micro switches figured i would try asking for advise here. I have a plasma table and it will not home, all it does is keep throwing active/ not active errors at whatever step in the homing process its at. I been trying to make it home for 2 days now. My cnc router that i run on linuxcnc has zero switches on it i just run it into the endstops to square it, seems way better then fighting this homing nightmare.
- Clive S
- Thank you received: 486
05 Nov 2020 20:49 - 05 Nov 2020 20:49 #188443
by Clive S
How about starting by posting your hal and ini files.
Some pics would help as well. How are they actually connected ?
Replied by Clive S on topic Limit/Home switches
My crystal ball is broke as much as your switches.Didnt know where else to post this, so before i break out my sledgehammer and destroy all my micro switches figured i would try asking for advise here. I have a plasma table and it will not home, all it does is keep throwing active/ not active errors at whatever step in the homing process its at. I been trying to make it home for 2 days now. My cnc router that i run on linuxcnc has zero switches on it i just run it into the endstops to square it, seems way better then fighting this homing nightmare.
Last edit: 05 Nov 2020 20:49 by Clive S.
- Hippy
05 Nov 2020 22:31 #188453
by Hippy
Replied by Hippy on topic Limit/Home switches
I got it figured out had to run into the switch at a higher speed to make it overshoot slightly, then it can run its routine. Before i was easing into the switch and it stopped to soon after tripping it.
- Clive S
05 Nov 2020 23:07 #188460
by Clive S
That is not the way to do it.
It should run into the switch then back off a small amount the come back to the switch very slow then back off a small amount to the home position
linuxcnc.org/docs/2.8/html/config/ini-homing.html
But its your machine.
- persei8
- Thank you received: 133
15 Nov 2020 18:22 #189469
by persei8
Replied by persei8 on topic Limit/Home switches
Maybe not related, but I had similar problems with microswitches not triggering and causing crashes into endstops while homing. It was not an issue of not going past the detent, they just didn't make contact. I removed them all and replaced them with hall effect sensors. Homing works perfect now.
Jim
Jim
Time to create page: 0.146 seconds
