4.19.1-rt3 kernel bug (BUG:Scheduling while atomic
  • bevins
  • bevins's Avatar Topic Author
  • Platinum Member
  • Platinum Member
26 Nov 2020 20:55 - 26 Nov 2020 21:09 #190368 by bevins
My machine is locking up and found it to be caused by a bug in the 4.19.1 RT3 kernel.
I installed the linuxmint iso. Is there another RT kernel I can use with Linuxmint?
Are all the iso's guys are creating using this kernel?
Last edit: 26 Nov 2020 21:09 by bevins.
  • bevins
  • Platinum Member
  • Platinum Member
26 Nov 2020 21:00 - 26 Nov 2020 21:01 #190369 by bevins
[   51.837353] IPv6: ADDRCONF(NETDEV_CHANGE): wlxd03745807435: link becomes ready
[ 2441.522786] BUG: scheduling while atomic: Xorg/1117/0x00000003
[ 2441.522787] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ip_tables x_tables 8192eu(OE) cfg80211 intel_rapl
Last edit: 26 Nov 2020 21:01 by bevins.
  • Moderator
  • Moderator
26 Nov 2020 21:09 #190373 by tommylight
I use this one daily on plenty of PC's, even on the one i am typing on although there is no machine attached to it.
ftp.us.debian.org/debian/pool/main/l/lin..._4.9.228-1_amd64.deb
  • bevins
  • Platinum Member
  • Platinum Member
26 Nov 2020 21:18 #190375 by bevins
go from 4.19 down to 4.9?
  • Moderator
  • Moderator
26 Nov 2020 22:09 #190377 by tommylight
Yes, it had the best latency from all the ones i tested. I dropped from 5.4 to 4.9 ! :)
Download that, install using gdebi, reboot and hold down shift key, choose that kernel in advanced options, test if it works ok.
If not just leave it there, GRUB will still load 4.19 by default. So in case it works you have to make it the default in GRUB.
The following user(s) said Thank You: bevins
  • bevins
  • Platinum Member
  • Platinum Member
27 Nov 2020 10:37 #190421 by bevins
Ok I am on that 4.9 kernel. We'll see how it goes.....
Thanks Tommy
  • bevins
  • Platinum Member
  • Platinum Member
27 Nov 2020 10:41 #190422 by bevins
Well..... no wifi drivers with that kernel.....
  • bevins
  • Platinum Member
  • Platinum Member
27 Nov 2020 12:32 #190429 by bevins
Is it worth trying to find the headers and recompile this older kernel with support for the 8192eu module?
  • bevins
  • Platinum Member
  • Platinum Member
27 Nov 2020 12:33 #190430 by bevins
Any other rt kernels around that would support the 8192eu module?
  • Moderator
  • Moderator
27 Nov 2020 12:40 #190431 by tommylight
packages.debian.org/bullseye/amd64/linux...-3-rt-amd64/download
That is the newest RT kernel, so should have drivers for your wifi.
Time to create page: 0.562 seconds
