4.19.1-rt3 kernel bug (BUG:Scheduling while atomic
- bevins
- Thank you received: 338
26 Nov 2020 20:55 - 26 Nov 2020 21:09 #190368
by bevins
4.19.1-rt3 kernel bug (BUG:Scheduling while atomic) was created by bevins
My machine is locking up and found it to be caused by a bug in the 4.19.1 RT3 kernel.
I installed the linuxmint iso. Is there another RT kernel I can use with Linuxmint?
Are all the iso's guys are creating using this kernel?
Last edit: 26 Nov 2020 21:09 by bevins.
- bevins
26 Nov 2020 21:00 - 26 Nov 2020 21:01 #190369
by bevins
Replied by bevins on topic 4.19.1-rt3 kernel bug (BUG:Scheduling while atomic
[ 51.837353] IPv6: ADDRCONF(NETDEV_CHANGE): wlxd03745807435: link becomes ready
[ 2441.522786] BUG: scheduling while atomic: Xorg/1117/0x00000003
[ 2441.522787] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ip_tables x_tables 8192eu(OE) cfg80211 intel_rapl
Last edit: 26 Nov 2020 21:01 by bevins.
- Thank you received: 7468
26 Nov 2020 21:09 #190373
Replied by tommylight on topic 4.19.1-rt3 kernel bug (BUG:Scheduling while atomic
I use this one daily on plenty of PC's, even on the one i am typing on although there is no machine attached to it.
ftp.us.debian.org/debian/pool/main/l/lin..._4.9.228-1_amd64.deb
- bevins
26 Nov 2020 21:18 #190375
by bevins
go from 4.19 down to 4.9?
26 Nov 2020 22:09 #190377
Yes, it had the best latency from all the ones i tested. I dropped from 5.4 to 4.9 !
Download that, install using gdebi, reboot and hold down shift key, choose that kernel in advanced options, test if it works ok.
If not just leave it there, GRUB will still load 4.19 by default. So in case it works you have to make it the default in GRUB.
The following user(s) said Thank You: bevins
- bevins
27 Nov 2020 10:37 #190421
by bevins
Ok I am on that 4.9 kernel. We'll see how it goes.....
Thanks Tommy
Thanks Tommy
- bevins
27 Nov 2020 10:41 #190422
by bevins
Well..... no wifi drivers with that kernel.....
- bevins
27 Nov 2020 12:32 #190429
by bevins
Is it worth trying to find the headers and recompile this older kernel with support for the 8192eu module?
- bevins
27 Nov 2020 12:33 #190430
by bevins
Any other rt kernels around that would support the 8192eu module?
27 Nov 2020 12:40 #190431
packages.debian.org/bullseye/amd64/linux...-3-rt-amd64/download
That is the newest RT kernel, so should have drivers for your wifi.
Time to create page: 0.097 seconds
