MDI Command for LINEAR_VELOCITY
- Blume
04 Dec 2020 18:58 #191056
by Blume
MDI Command for LINEAR_VELOCITY was created by Blume
hi
I am looking for an MDI command that i can change the Linear Velocity in Axis without change the bar.
thanks
thanks
- Thank you received: 7468
12 Dec 2020 17:32 #191748
Replied by tommylight on topic MDI Command for LINEAR_VELOCITY
Use the Fnnnn before the G1 Xnnn Ynnn Znnn
Something like F1000
then G1 X500
That will move the machine at 1000mm per minute and 500mm away from 0.
then G1 X500
Time to create page: 0.187 seconds
