multiple motion probe inputs
16 Dec 2020 19:28 - 16 Dec 2020 19:32 #192158 by Stran_ge
multiple motion probe inputs was created by Stran_ge
Hello
At the moment i am using a touch probe (Drewtronics) and a tool length sensor via 2 inputs on my mesa card by the use of "or2".
Both probes are normally closed. The touch probe is used with a cable. I use Probe Basic as Screenset.
My problem is, that i disconnect my touch probe after the initial probing of my stock and when i do that the tool length sensor obviously doesnt work anymore since the motion.probe-input is already triggered.
So currently i have to connect my touch probe to use the tool length sensor, which is, as you can imagine, less than ideal.
Is there a smart way to solve this problem via hal or script functions ?
This is my probing part in the hal.
loadrt or2
addf or2.0 servo-thread
net probe-input-A    or2.0.in0 <= hm2_7i76e.0.7i76.0.0.input-08-not
net probe-input-B     or2.0.in1 <= hm2_7i76e.0.7i76.0.0.input-09-not
net probe-input         motion.probe-input <= or2.0.out
Best regards
Nils
Last edit: 16 Dec 2020 19:32 by Stran_ge.
16 Dec 2020 19:30 #192159 by alkabal
Replied by alkabal on topic multiple motion probe inputs
Hi
I face 100% the same problem but for now i haven't cherched for the good solution excepted i manage this directly inside macro with probe screen V2, but i plan to found a autonomous way and at same time i like to prevent spindle starting if the probe is detected.
Br
16 Dec 2020 19:32 - 09 Jan 2021 02:36 #192161 by alkabal
For now i'm here, using motion.digital for inhibit Touch probe or tool setter
# --- probe signals separated for probe + toolsetter with status checking and possible bypass from macro ---
# --- some link for securing probe are done inside spindle and orient config--
loadrt or2                    names=or2.combined-touch
loadrt and2                   names=and2.combined-probe
loadrt and2                   names=and2.combined-setter
loadrt not                    names=not.combined-probe-on
loadrt not                    names=not.combined-setter-on
addf or2.combined-touch       servo-thread
addf not.combined-probe-on    servo-thread
addf not.combined-setter-on   servo-thread
addf and2.combined-probe      servo-thread
addf and2.combined-setter     servo-thread
net touch-probe-not-in        <= motion.digital-out-01
net touch-probe-not-in        => not.combined-probe-on.in
net touch-setter-not-in       <= motion.digital-out-02
net touch-setter-not-in       => not.combined-setter-on.in
net touch-setter              <= [HMOT](CARD0).7i76.0.0.input-14           # probe is NC NPN with pullup
#or
#net touch-setter              <= [HMOT](CARD0).7i76.0.0.input-14-not       # probe is NC PNP
net touch-probe               => and2.combined-probe.in0
net touch-probe-on-psng       <= not.combined-probe-on.out              # M65 P1 activate / M64 P1 inhibit
net touch-probe-on-psng       => and2.combined-probe.in1;
net touch-probe-and2-psng     <= and2.combined-probe.out
net touch-probe-and2-psng     => or2.combined-touch.in0
net touch-setter              <= [HMOT](CARD0).7i76.0.0.input-15           # setter is NC NPN with pullup
#or
#net touch-setter              <= [HMOT](CARD0).7i76.0.0.input-15-not       # setter is NC PNP
net touch-setter              => and2.combined-setter.in0
net touch-setter-on-psng      <= not.combined-setter-on.out                # M65 P2 activate / M64 P2 inhibit
net touch-setter-on-psng      => and2.combined-setter.in1
net touch-setter-and2-psng    <= and2.combined-setter.out
net touch-setter-and2-psng    => or2.combined-touch.in1
net touch-probe-combined      <= or2.combined-touch.out
net touch-probe-combined      => motion.probe-input
edited message for clarification
Last edit: 09 Jan 2021 02:36 by alkabal.
16 Dec 2020 19:35 #192163 by alkabal
So wanted in this code is allow probe to be automatically deactivated until is see as wired. NPN NC with pull up.
I have see in other topic a guy simply using a timedelay as workaround.
Br
16 Dec 2020 19:40 #192165 by Stran_ge
Replied by Stran_ge on topic multiple motion probe inputs
that seems quite complex, kinda hard for me to make sense of this.
Thank you anyway.
16 Dec 2020 19:41 #192166 by alkabal
github.com/alkabal/probe-screen-ng
But the change are for now not finalized...
16 Dec 2020 19:44 #192167 by Stran_ge
i dont want to change my screenset tho.
16 Dec 2020 19:44 - 16 Dec 2020 19:45 #192168 by alkabal
Well
i have do like you, using or2
But after that i have wanted to add a possible deactivation using motion.digital-out-01 and motion.digital-out-02 (using M64 M65 command for make this value 1 or 0)
i have faced the fact this motion pin need to be inverted from 1/0 to 0/1 so i have a a not function allowing to reverse signal.
Last edit: 16 Dec 2020 19:45 by alkabal.
16 Dec 2020 19:45 #192169 by alkabal
I have put link if you need to study how i have managed the activation/deactivation for input.
16 Dec 2020 19:52 #192172 by Stran_ge
that would indeed be helpful
Time to create page: 3.849 seconds
