multiple motion probe inputs
5 years 10 months ago #192167 by Stran_ge
i dont want to change my screenset tho.
5 years 10 months ago - 5 years 10 months ago #192168 by alkabal
Well
i have do like you, using or2
But after that i have wanted to add a possible deactivation using motion.digital-out-01 and motion.digital-out-02 (using M64 M65 command for make this value 1 or 0)
i have faced the fact this motion pin need to be inverted from 1/0 to 0/1 so i have a a not function allowing to reverse signal.
Last edit: 5 years 10 months ago by alkabal.
5 years 10 months ago #192169 by alkabal
I have put link if you need to study how i have managed the activation/deactivation for input.
5 years 10 months ago #192172 by Stran_ge
that would indeed be helpful
5 years 10 months ago #192175 by tommylight
Why not use the "NOT" hal component on both the inputs?
That way even when you disconnect them, to HAL nothing has changed.
5 years 10 months ago - 5 years 10 months ago #192181 by Stran_ge
i did use not on both inputs since they are normaly closed switches.
hm2_7i76e.0.7i76.0.0.input-08-not hm2_7i76e.0.7i76.0.0.input-09-not
Last edit: 5 years 10 months ago by Stran_ge.
Time to create page: 0.280 seconds
