- LinuxCNC
- General LinuxCNC Questions
- How to read "Machine configuration directory" in HAL userspace component
- freisei
24 Dec 2020 13:20 #193107
by freisei
How to read "Machine configuration directory" in HAL userspace component was created by freisei
Hi!
i am writing a timeinterval-component, and i want to save same data in configuration-directory.
I have often seen the os.environ 'CONFIG_DIR' in python - i think this is what i need.
If i try to get this in c i get an empty variable:
my componet was loaded after linuxcnc was startet with
Is there a header-file to include to get more of linuxcnc-environment?
Greets from Bavaria
Freisei
const char* s = getenv("CONFIG_DIR");
printf("CONFIG_DIR :%s\n",(s!=NULL)? s : "getenv returned NULL");
printf("end test\n");my componet was loaded after linuxcnc was startet with
halcmd loadusr -W timeinterval filename=lubrication_timeinterval.savIs there a header-file to include to get more of linuxcnc-environment?
Greets from Bavaria
Freisei
- freisei
25 Dec 2020 10:16 #193169
by freisei
Replied by freisei on topic How to read "Machine configuration directory" in HAL userspace component
i´ve found that the current working directory is the config-dir, when the component is loaded from linuxcnc himself/halfile.
But for develement it would be great if someone know how to access the "config_dir" Varaible.
Greets from Bavaria
Freisei
Greets from Bavaria
Freisei
- udoS
- Thank you received: 25
31 Oct 2022 06:06 #255544
by udoS
Replied by udoS on topic How to read "Machine configuration directory" in HAL userspace component
freisei
Hallo freisei
did you find a solution getting the "config_dir" programmatically;
Best Regards
Hallo freisei
Best Regards
- freisei
05 Nov 2022 14:55 #256014
by freisei
no sorry.
- udoS
21 Nov 2022 19:18 #257248
by udoS
Hi @freisei
I found a way to get the ini Directory; if thats what you where looking for;
Best Regards
Best Regards
- freisei
22 Nov 2022 08:01 #257307
by freisei
Hi udoS,
fine!
Would be great if you share your answer, so others can benefit from it, too.
Thanks!
fine!
Thanks!
- udoS
22 Nov 2022 11:14 #257319
by udoS
@freisei
some pree condition:
Linuxcnc must be running;
If you start Linuxcnc then you can querry:
$ ps aux | grep "linuxcnc"
LinuxCNC starts with "/bin/bash /usr/bin/linuxcnc"
Now if you start LinuxCNC, LinuxCNC starts/calls for "halui -ini" and "io -ini"
If you querry now for
$ ps aux | grep "halui -ini" or
$ ps aux | grep "io -ini"
then you get as return the process info along with the path;
io -ini /home/udos/linuxcnc/configs/sim.axis.gantry/gantry_mm.ini
Here the code I have used in Qt 5.15.2:
22 Nov 2022 23:45 #257405
Replied by andypugh on topic How to read "Machine configuration directory" in HAL userspace component
Maybe you can run the linuxcnc_info script?
- dgarrett
- Thank you received: 297
23 Nov 2022 01:07 - 23 Nov 2022 01:09 #257412
by dgarrett
Replied by dgarrett on topic How to read "Machine configuration directory" in HAL userspace component
Processes started by linuxcnc (like [DISPLAY]DISPLAY)
inherit the environmental variables 'INI_FILE_NAME'
Python example within a [DISPLAY]DISPLAY program:
import os
print(os.environ.get("INI_FILE_NAME"))
The ini setting is also available in stat() and
may be obtained from programs not started by linuxcnc
(if Run-In-PLace, source rip_environment first):
$ python -c "import linuxcnc;s=linuxcnc.stat();s.poll();print(s.ini_filename)"
Note the item namings are different (INI_FILE_NAME and ini_filename)
import os
Last edit: 23 Nov 2022 01:09 by dgarrett.
- udoS
23 Nov 2022 06:27 #257429
by udoS
Thanks for the info;
@andypugh
How does that get me the path to a running linuxcnc ?
@dgarrett
I'm all in Qt and/or c++; No No No Python; what so ever;
with "The ini setting is also available in stat()" .. are you referring to NML ?
then what is the call for it ? could be used in the Lcnc_QtCpp_HMI;
What I have here is an interface into LinuxCNC/HAL in an attempt to build a Linuxcnc-IDE;
Qt 5.15.2, with Creator 8.0.1, c++17; any help Wellcome !
Best Regards
@andypugh
@dgarrett
Best Regards
- LinuxCNC
Time to create page: 0.262 seconds
