write to Tool Table (specifically pocket) from O Code
27 Dec 2020 02:56 #193261 by jhandel
Howdy all,
Is there a way to write to a tools pocket via O code (or python that I can then expose as a custom G or M code?
Josh
27 Dec 2020 03:39 #193263 by Aciera
Since the tool table is stored in a text file you could maybe try to use a bash script to modify it. Another question is whether that modified file can then be reloaded while running the Gcode.
27 Dec 2020 19:33 #193307 by jhandel
Hoping there is a way though Python + Remap or straight O-code/G-code...
There is G10, but that seems to only set tool length not tool diameter and not any other props (like pocket, which is what I am hunting for now)..
And there doesn't seem to be a way to read the table either :-(
15 Jan 2021 01:15 - 15 Jan 2021 01:16 #195388 by mikeross
Try M61
I accidentally had my machine set to random tool changer in the INI when doing an initial configuration and using M61 it seems that it looks for both the tool # and the pocket. So you may be able to set T to pocket Q by using M61 but I haven't tried myself.
If you don't have random tool changer configured M61 is content with just the tool # T
Last edit: 15 Jan 2021 01:16 by mikeross.
Time to create page: 0.240 seconds
