Second Probe
5 years 9 months ago #194456 by JohnnyCNC
Replied by JohnnyCNC on topic Second Probe
I'm using multiple or2s so ignore the limit switch ones. This setup is working for me.
loadrt or2 names=or2.x_limit_switch,or2.y_limit_switch,or2.z_limit_switch,or2.probe_in
addf or2.probe_in servo-thread
addf or2.x_limit_switch servo-thread
addf or2.y_limit_switch servo-thread
addf or2.z_limit_switch servo-thread
#Touch-plate
net deb-tplate-in debounce.0.0.in <= hm2_5i25.0.7i76.0.0.input-05-not
net tplate-in debounce.0.0.out
net tplate-in => or2.probe_in.in0
#3d Probe
net deb-probe-in debounce.2.0.in <= hm2_5i25.0.7i76.0.0.input-11-not
net probe-in debounce.2.0.out
net probe-in => or2.probe_in.in1
5 years 9 months ago - 5 years 9 months ago #194460 by alkabal
Replied by alkabal on topic Second Probe
I copy past again, i use this config all the days at this moment.
the two pass option is imo a good things allow you to add more or2 and2 and other in other place in the file or in other hal llike postgui
# --- probe signals separated for probe + toolsetter with status checking and possible bypass from macro --- # --- some link for securing probe are done inside spindle and orient config-- loadrt or2 names=or2.combined-touch loadrt and2 names=and2.combined-probe loadrt and2 names=and2.combined-setter loadrt not names=not.combined-probe-on loadrt not names=not.combined-setter-on addf or2.combined-touch servo-thread addf not.combined-probe-on servo-thread addf not.combined-setter-on servo-thread addf and2.combined-probe servo-thread addf and2.combined-setter servo-thread net touch-probe-not-in <= motion.digital-out-01 net touch-probe-not-in => not.combined-probe-on.in net touch-setter-not-in <= motion.digital-out-02 net touch-setter-not-in => not.combined-setter-on.in net touch-setter <= [HMOT](CARD0).7i76.0.0.input-14 # probe is NC NPN with pullup #or #net touch-setter <= [HMOT](CARD0).7i76.0.0.input-14-not # probe is NC PNP net touch-probe => and2.combined-probe.in0 net touch-probe-on-psng <= not.combined-probe-on.out # M65 P1 activate / M64 P1 inhibit net touch-probe-on-psng => and2.combined-probe.in1; net touch-probe-and2-psng <= and2.combined-probe.out net touch-probe-and2-psng => or2.combined-touch.in0 net touch-setter <= [HMOT](CARD0).7i76.0.0.input-15 # setter is NC NPN with pullup #or #net touch-setter <= [HMOT](CARD0).7i76.0.0.input-15-not # setter is NC PNP net touch-setter => and2.combined-setter.in0 net touch-setter-on-psng <= not.combined-setter-on.out # M65 P2 activate / M64 P2 inhibit net touch-setter-on-psng => and2.combined-setter.in1 net touch-setter-and2-psng <= and2.combined-setter.out net touch-setter-and2-psng => or2.combined-touch.in1 net touch-probe-combined <= or2.combined-touch.out net touch-probe-combined => motion.probe-input
edited message for clarification
Last edit: 5 years 9 months ago by alkabal.
5 years 9 months ago #194555 by mrmike
Replied by mrmike on topic Second Probe
The issue I seem to have with this setup is the probe being tripped anytime \I have the NC probe plugged in. I checked the hal pins on the HAL configuration window, and the probes show red until I trip either of the probes. When I unplug the NC probe, the Z-axis moves freely, and will home.
I by-passes the wiring from the NC probe in case there was some interference, and changed the gpio.
When I use M65/M64 to turn off the NC probe, all is well, when I activate that probe, the Z-axis
I have used the above script, only changing the and2 and not to one line for now.
Any suggestions?
5 years 9 months ago - 5 years 9 months ago #194558 by alkabal
It seem you need to use something like [HMOT] (CARD0) .7i76.0.0.input-14-not
Maybe your probe is NC but it is PNP or NPN can do the difference !
and2.combined-probe.in0 need to be FALSE with probe connected and TRUE when triggered or unconnected
and2.combined-setter.in0 need to be FALSE with setter connected and TRUE when triggered or unconnected
so you need "your-input-pin-not" or use a not component
5 years 9 months ago #194756 by andypugh
Replied by andypugh on topic Second Probe
mrmike wrote: Any suggestions?
Have a look near the end of the similar thread previously linked to where I show a custom HAL component that latches the state of up to 8 probe inputs when the machine is turned on (F2) and then drives the motion.probe-in pin whenever is sees a _change_ in any input.
5 years 4 months ago #212780 by hoffb77
Replied by hoffb77 on topic Second Probe
Easy and Cheap....Plus it keeps debris out of the jack.
Time to create page: 0.189 seconds
