Second Probe
  • mrmike
  • mrmike's Avatar Topic Author
  • Junior Member
  • Junior Member
07 Jan 2021 04:56 #194320 by mrmike
Second Probe was created by mrmike
How would one add a second, inverted probed onto a 7i96 card? I currently have a touch probe that closes a ground loop between my router bit and a metal plate. I built a touch probe for G-Ripper that opens a ground loop, therefore they can't be paralleled. Does one need to use motion.probe? Can one add another pin that will act like the same?
07 Jan 2021 10:17 #194344 by alkabal
  • mrmike
  • Junior Member
  • Junior Member
07 Jan 2021 19:41 - 07 Jan 2021 19:45 #194400 by mrmike
Replied by mrmike on topic Second Probe
I guess if I look at the forum list, I might have seen this :)
I followed the text file you posted, but the error I get upon opening axis is that and2 already exists at loadrt and2 names=and2.combined.setter.
Here is what I changes the text to, in my custom.hal file if that might matter:
# --- probe signals separated for probe + toolsetter with status checking and possible bypass from macro ---
loadrt or2 names=or2.combined-touch
loadrt and2 names=and2.combined-probe
loadrt and2 names=and2.combined-setter
loadrt not names=not.combined-probe-on
loadrt not names=not.combined-setter-on
addf or2.combined-touch servo-thread
addf not.combined-probe-on servo-thread
addf not.combined-setter-on servo-thread
addf and2.combined-probe servo-thread
addf and2.combined-setter servo-thread
net touch-probe-not-in <= motion.digital-out-01
net touch-probe-not-in => not.combined-probe-on.in
net touch-setter-not-in <= motion.digital-out-02
net touch-setter-not-in => not.combined-setter-on.in
net touch-probe <= hm2_7i96.0.gpio.006.in
#net touch-probe <= hm2_7i96.0.0.input-14
net touch-probe => and2.combined-probe.in0
net touch-probe-on-psng <= not.combined-probe-on.out # M65 P1 activate / M64 P1 inhibit output from macro #motion.digital-out-01
net touch-probe-on-psng => and2.combined-probe.in1;
net touch-probe-and2-psng <= and2.combined-probe.out
net touch-probe-and2-psng => or2.combined-touch.in0
net touch-setter <= hm2_7i96.0.gpio.008.in_not
net touch-setter => and2.combined-setter.in0
net touch-setter-on-psng <= not.combined-setter-on.out # M65 P2 activate / M64 P2 inhibit output from macro #motion.digital-out-02
net touch-setter-on-psng => and2.combined-setter.in1
net touch-setter-and2-psng <= and2.combined-setter.out
net touch-setter-and2-psng => or2.combined-touch.in1
net touch-probe-combined <= or2.combined-touch.out
net touch-probe-combined => motion.probe-input
Last edit: 07 Jan 2021 19:45 by mrmike. Reason: Added hal component
07 Jan 2021 20:10 #194407 by alkabal
Replied by alkabal on topic Second Probe
I appologize with this setup you need to use
[HAL]
TWOPASS=ON
or you need to do the loadrt in only one line like thi exemple
loadrt and2 names=and2.combined-probe, and2.combined-setter
loadrt not names=not.combined-probe-on, not.combined-setter-on
  • mrmike
  • Junior Member
  • Junior Member
07 Jan 2021 23:10 #194428 by mrmike
That worked, but I had to do this in the hal fil, change from
#loadrt [HOSTMOT2](DRIVER) board_ip=[HOSTMOT2](IPADDRESS) config="num_encoders=[HOSTMOT2](ENCODERS) num_stepgens=[HOSTMOT2](STEPGENS) num_pwmgens=[HOSTMOT2](PWMGENS) sserial_port_0=[HOSTMOT2](SSERIAL_PORT)"
to this
loadrt hm2_eth board_ip="192.168.1.121" config="num_encoders=1 num_stepgens=4 num_pwmgens=1 sserial_port_0=1"
The debug from starting the file was telling me I had a rtapi-app-main:permission denied in the start-up
  • mrmike
  • Junior Member
  • Junior Member
07 Jan 2021 23:30 #194432 by mrmike
BUT,
now when I start the cnc program, I can't home the Z axis easily, as it stops on probe input, and then the Y axis claims it is not in sync (dual motors). I took out the twopass, and tried
starting the cnc debuged out "Invalid parameter 'and2.combined-setter'
08 Jan 2021 01:56 #194456 by JohnnyCNC
Replied by JohnnyCNC on topic Second Probe
I'm using multiple or2s so ignore the limit switch ones. This setup is working for me.
loadrt or2 names=or2.x_limit_switch,or2.y_limit_switch,or2.z_limit_switch,or2.probe_in
addf or2.probe_in servo-thread
addf or2.x_limit_switch servo-thread
addf or2.y_limit_switch servo-thread
addf or2.z_limit_switch servo-thread
#Touch-plate
net deb-tplate-in debounce.0.0.in <= hm2_5i25.0.7i76.0.0.input-05-not
net tplate-in debounce.0.0.out
net tplate-in => or2.probe_in.in0
#3d Probe
net deb-probe-in debounce.2.0.in <= hm2_5i25.0.7i76.0.0.input-11-not
net probe-in debounce.2.0.out
net probe-in => or2.probe_in.in1
08 Jan 2021 02:33 - 09 Jan 2021 02:33 #194460 by alkabal
I copy past again, i use this config all the days at this moment.
the two pass option is imo a good things allow you to add more or2 and2 and other in other place in the file or in other hal llike postgui
# --- some link for securing probe are done inside spindle and orient config--
net touch-setter              <= [HMOT](CARD0).7i76.0.0.input-14           # probe is NC NPN with pullup
#or
#net touch-setter              <= [HMOT](CARD0).7i76.0.0.input-14-not       # probe is NC PNP
net touch-setter              <= [HMOT](CARD0).7i76.0.0.input-15           # setter is NC NPN with pullup
#or
#net touch-setter              <= [HMOT](CARD0).7i76.0.0.input-15-not       # setter is NC PNP
edited message for clarification
Last edit: 09 Jan 2021 02:33 by alkabal.
  • mrmike
  • Junior Member
  • Junior Member
09 Jan 2021 01:21 #194555 by mrmike
The issue I seem to have with this setup is the probe being tripped anytime \I have the NC probe plugged in. I checked the hal pins on the HAL configuration window, and the probes show red until I trip either of the probes. When I unplug the NC probe, the Z-axis moves freely, and will home.
I by-passes the wiring from the NC probe in case there was some interference, and changed the gpio.
When I use M65/M64 to turn off the NC probe, all is well, when I activate that probe, the Z-axis
I have used the above script, only changing the and2 and not to one line for now.
Any suggestions?
09 Jan 2021 02:20 - 09 Jan 2021 02:28 #194558 by alkabal
It seem you need to use something like [HMOT] (CARD0) .7i76.0.0.input-14-not
Maybe your probe is NC but it is PNP or NPN can do the difference !
and2.combined-probe.in0 need to be FALSE with probe connected and TRUE when triggered or unconnected
and2.combined-setter.in0 need to be FALSE with setter connected and TRUE when triggered or unconnected
so you need "your-input-pin-not" or use a not component
Last edit: 09 Jan 2021 02:28 by alkabal.
Time to create page: 0.137 seconds
