cant see file names in geany <File><open>
5 years 9 months ago #194413 by joekline9
on debian 10 buster linuxcnc 2.8. Geany editor, I see no file names only folders when I do <File><Open>.
If I do <File><Save As> I do see filenames.
I have reinstalled geany. done updates etc but no change.
I have it on 2 different machines with same problem.
Could it be GTK 3 problem?
5 years 9 months ago #194430 by tommylight
In the lower left corner, above the "view", "cancel","open" there is a drop down menu, choose "all files".
5 years 9 months ago #194556 by joekline9
"All Files" doesn't help. Someone else must be having this problem.
I have Debian 10 Buster on 3 different machines and have tried from 2 different
live usb sticks. all have the same problem.
I have Geany 1.33 on a Ubuntu 18 machine and it works OK but if I boot on the Live Buster usb the problem is there.
5 years 9 months ago #194580 by tommylight
5 years 9 months ago #194592 by joekline9
Yes it is mounted.
Yes I can browse it.
I can run Linuxcnc etc. Geany works but I dont see filename in <File><Open>
I only see folders. I can edit files from a browser or command line.
5 years 9 months ago #194593 by tommylight
There is nothing on the net about such issue!
Try using the file browser, right click on a file you want to open then choose "open with" and geany, or if there is no geany choose "other application", then scroll till you find geany and click on it.
Time to create page: 0.053 seconds
