Linuxcnc 2.8.1 crash randomly
- mikeross
- Thank you received: 3
10 Jan 2021 01:40 - 10 Jan 2021 04:26 #194670
by mikeross
Linuxcnc 2.8.1 crash randomly was created by mikeross
I've had my mill for many years and it was working pretty reliably for the last few years. I recently (~1month) updated from 2.7 to 2.8.1
Now I've experienced twice linuxcnc crashing completely mid-use. I don't remember what I was doing the 1st time and I kind of wrote it off as a 1 time thing but its done it again which tells me that something is wrong and it will likely happen again.
This time I was just jogging around, not using any G code file - mostly just through the XHC-HB04 USB pendant and a few MDI commands.
My uneducated eye tells me its related to tkinter and / or python 2.7 but I really don't know what to do about it...
I do know that the pendant is not configured correctly and I've been blissfully ignoring the messages as they haven't caused any issues to date.
Any help is appreciated.
Mike
Mike
Last edit: 10 Jan 2021 04:26 by mikeross. Reason: tkinter not tinker
- mikeross
10 Jan 2021 04:30 #194681
by mikeross
Replied by mikeross on topic Linuxcnc 2.8.1 crash randomly
It also says out of memory so not sure why that should be the case, I need to check but the PC should have plenty of RAM.
- BeagleBrainz
- Visitor
10 Jan 2021 21:56 - 10 Jan 2021 21:59 #194786
by BeagleBrainz
Replied by BeagleBrainz on topic Linuxcnc 2.8.1 crash randomly
Generally if you look through through the linuxcnc report and look for the the bit that mentions shutting down there is a good chance the lines immediately before give a clue as to what went pear shaped.
Looking through the error log Linuxcnc appears to start the shutdown procedure after the probe was tripped a number of times during a coordinate jog.
I would start investigating why this is happening. Even if the probe was not connected I would investigate it just as thoroughly.
Probe tripped during a coordinate jog.
Running HAL shutdown scriptI would start investigating why this is happening. Even if the probe was not connected I would investigate it just as thoroughly.
Last edit: 10 Jan 2021 21:59 by BeagleBrainz.
- Thank you received: 2175
10 Jan 2021 22:48 #194798
Replied by cmorley on topic Linuxcnc 2.8.1 crash randomly
And check that all the ram is good.
- mikeross
10 Jan 2021 23:02 #194801
by mikeross
I'll go check the RAM.
I don't think that the probe trips are directly related.
The number of probe trips roughly correspond to me using the "probe input" as my tool height setter, and I had been jogging down until touching the setter which trips the probe as a means of setting tool heights.
Is there a way to get more details on when the errors occur? As pointed out I think the probe trips are misleading and where well before the actual crash.
I'm also going to look at my tool table - I think I put a #99 tool in there - and this may have happened after I did that
- Thank you received: 4652
11 Jan 2021 13:44 #194903
Replied by andypugh on topic Linuxcnc 2.8.1 crash randomly
Does the crash stop the machine / motion control system, or just the GUI?
ie, does the job complete as normal with a frozen interface, or is the part ruined too?
- mikeross
11 Jan 2021 14:26 #194912
by mikeross
The machine stops, the spindle stops so yes the part is ruined. I'm going to just leave the machine on today while I'm doing other things to see if it repeats again.
Time to create page: 0.094 seconds
