Parameter #5203 ?
- JohnnyCNC
- Thank you received: 115
15 Jan 2021 02:04 #195391
by JohnnyCNC
Parameter #5203 ? was created by JohnnyCNC
Does anyone know what parameter #5203 is? I am looking at the following line in probe_z_minus_wco.ngc
#<workspace_z> = #[5203 + [20 * #5220]]
#5203 is not in the reference and would fall between these.
5211-5219 - "G92" offset for X, Y, Z, A, B, C, U, V & W. Persistent.
5210 - 1 if "G92" offset is currently applied, 0 otherwise. Persistent.
- Thank you received: 2175
15 Jan 2021 02:13 #195392
Replied by cmorley on topic Parameter #5203 ?
I would guess then it is being used as a temporary variable.
- JohnnyCNC
15 Jan 2021 02:47 #195395
by JohnnyCNC
Replied by JohnnyCNC on topic Parameter #5203 ?
I did a grep through all of the macros and it is always used but never set. Ahhh but the light just went on. It is just a reference starting point. Say we are in G55 then #5220 would equal 2. (20 * 2) = 40. (5203 + 40) = 5243 which would be the Z location in G55.
5241-5250 - Coordinate System 2, G55 for X, Y, Z, A, B, C, U, V, W & R. Persistent.
probe_cal_round_boss.ngc: #<workspace_z> = #[5203 + [20 * #5220]]
probe_cal_square_boss.ngc: #<workspace_z> = #[5203 + [20 * #5220]]
probe_rect_boss.ngc: #<workspace_z> = #[5203 + [20 * #5220]]
probe_ridge_x.ngc: #<workspace_z> = #[5203 + [20 * #5220]]
probe_ridge_y.ngc: #<workspace_z> = #[5203 + [20 * #5220]]
probe_round_boss.ngc: #<workspace_z> = #[5203 + [20 * #5220]]
probe_z_minus_sub.ngc: #<workspace_z> = #[5203 + [20 * #5220]]
probe_z_minus_wco.ngc: #<workspace_z> = #[5203 + [20 * #5220]]
Thanks you
Thanks you
