Yaskawa servo options
12 Feb 2021 13:06 #198527 by andypugh
Replied by andypugh on topic Yaskawa servo options
i've been using absolute encoders with MR-J2S-B's on my home mill for 10 year now... when i turn on the machine linuxcnc always comes up already homed. so i don't have a habit to rehome it. though it won't bring a slightest problem if i do it by accident or intentionally...
My absolute encoders aren't really absolute. What I have are single-turn-absolute resolvers and a bit of HAL that uses the position.txt file to work out where the axis really is.
Sometimes that file does not get saved, and I need to reset the system.
12 Feb 2021 14:54 #198539 by dm17ry
Replied by dm17ry on topic Yaskawa servo options
Typo. Should have been "your driver".
oh, ok. well, probably. i can keep motor motor offset in the amp eeprom or card's flash and output position which is 0 at home position. but already present motor-offset fit perfectly, so i thought it's a shame not to reuse it.. but i really like that now i have joints get homed automatically when amps say they are absolute. and unhomed when amps report position loss due to motor disconnection or discharged backup battery. seems like a natural behavior to me. what's the point of an open source software then if i have to give it up? ;)
btw, in the latest J5 series mitsubishi finally came up with battery-less absolute encoders. i haven't seen any in person yet, but as far as i understand they are harvesting motor's EMF to power up encoder electronics when an unpowered motor gets rotated by an outside force. pretty neat. because usually when backup batteries discharge after a few years and users miss it - just the right time to completely forget how to re-home the machine :)
12 Feb 2021 18:07 #198555 by andypugh
[oh, ok. well, probably. i can keep motor motor offset in the amp eeprom or card's flash and output position which is 0 at home position. but already present motor-offset fit perfectly, so i thought it's a shame not to reuse it.
Can you give a link to documentation or code?
15 Feb 2021 16:24 #198949 by dm17ry
linuxcnc component description: yurtaev.com/nyx24.html
2.8 fork with my patches: github.com/yur7aev/linuxcnc/tree/nyx2.8
sample linuxcnc configs: github.com/yur7aev/linuxcnc/tree/nyx2.8/configs/nyx
24 Feb 2021 12:34 #199971 by andypugh
Sorry, I got busy and rather dropped the ball on this one.
"$ sudo apt install -t stretch python-gtksourceview2 # this package is missing in buster"
It is backported via LinuxCNC. If the LinuxCNC deb archive is configured then it should install from there.
I am still fuzzy on whether your board and driver code will work on an otherwise unmodified LinuxCNC.
12 Jan 2022 21:10 - 12 Jan 2022 21:14 #231611 by chris@cnc
Replied by chris@cnc on topic Yaskawa servo options
I have a sgd7w servo drive and mechatrolink III control card. It’s possible to communicate with your comp over ethernet?
Last edit: 12 Jan 2022 21:14 by chris@cnc.
06 Nov 2023 13:09 - 06 Nov 2023 13:12 #284695 by 1192342018
Replied by 1192342018 on topic Yaskawa servo options
Last edit: 06 Nov 2023 13:12 by 1192342018.
22 Oct 2026 10:51 #350394 by stefan63
Replied by stefan63 on topic Yaskawa servo options
How do i buy this card an how much does it cost?
yurtaev.com/yssc3p.html
The following user(s) said Thank You: NWE
22 Oct 2026 15:57 #350408 by NWE
Replied by NWE on topic Yaskawa servo options
I see an email half way down the front page yurtaev.com/ with instructions to contact that email for purchasing cards.
Time to create page: 0.237 seconds
