Linux CNC on Macbook 2012
- Creative25
- Thank you received: 11
28 Feb 2021 17:26 #200442
by Creative25
Linux CNC on Macbook 2012 was created by Creative25
Since I am still struggling to find a computer for Linuxcnc,
I tried the Live Usb on my Macbook Pro 2012
Latency seems to be ok.
So I installed Linux CNC on an externel hard drive as well as on a USB stick.
Firtst Grub installation failed. After I Connected my computer to the internet via eternet cable from a Wireless extender installation was a breeze no issues at all.
My question is wat is better External USB hard drive or USB flash drive. I am concerned if the USB flash drive will last, especially the swap partition. On the other hans Usb flash drive is much more convenient.
- Thank you received: 7468
28 Feb 2021 18:55 #200452
Replied by tommylight on topic Linux CNC on Macbook 2012
Hard drive is faster, much faster.
USB will last plenty but are inherently slow at everything.
- Creative25
28 Feb 2021 19:15 #200456
by Creative25
Replied by Creative25 on topic Linux CNC on Macbook 2012
Just wonder in my case
Hard drive is Usb2
Usb Stick is usb3
In this case is the Hard Drive still faster?
Hard drive is Usb2
Usb Stick is usb3
01 Mar 2021 01:18 #200495
Yes.Just wonder in my case
Hard drive is Usb2
Usb Stick is usb3
- Thank you received: 4652
02 Mar 2021 22:22 #200837
Replied by andypugh on topic Linux CNC on Macbook 2012
Have you a plan to connect hardware to the Macbook, or is this just for simulation?
Ethernet is probably the only option, and I am not sure if they had dropped Ethernet on Macbooks by 2012.
- Creative25
03 Mar 2021 20:44 #200939
by Creative25
It is the Last Macbook with CD drive built in.
Yes it has a Eternet port.
I don't get wifi to work. Because for driver installation it wants to install a different kernel as well. Latency seems to be ok.
I plan to use it for getting started with my plasma table.
When I find a Good Computer for it I will replace the Macbook.
04 Mar 2021 00:02 #200964
I keep meaning to try compiling LinuxCNC on a Mac. Linux and OSX are not _that_ far apart.
But, I have so many other ways to waste my time instead.
- Creative25
04 Mar 2021 08:38 #200999
by Creative25
True it’s a waste of time.
If you port it to OSX you have all these functions that you don’t want. Sleep mode energy saving mode etc. That you don’t want and you have to disable them. I rather stick to Linux. I have a MacBook 4.1 for the kids it is a great Linux machine.
- Creative25
13 Mar 2021 09:00 #202075
by Creative25
Just some update.
I found Gmocappy Interface is a bit too Lage for a MacBook 13 inch with no Retina display. Part of it gets covered by the bottom panel of Xfce. Apparently The Gmocappy Interface can not be resized because it is already at minimum hight.
I found two workarounds so far.
Move the bottom Xfce panel to the side.
Or use full screen mode.
- asderasd
02 Mar 2022 19:15 - 06 Mar 2022 14:30 #236207
by asderasd
Replied by asderasd on topic Linux CNC on Macbook 2012
Answering the question of what is better, an external hard drive or a flash drive, I can say with certainty that the hard drive will be much better. First of all, the reading speed from the hard drive is much faster than the reading speed from a USB drive. Secondly, you can store more files on the hard drive because it is very rare to find a USB drive with a large capacity. Third,
hard drive data recovery
is easier and faster than flash drive data recovery. These are the most significant advantages of a hard drive for me. If I list all of them, this discussion could continue for a long time.
Last edit: 06 Mar 2022 14:30 by asderasd.
Time to create page: 0.130 seconds
