Run program from line... from a shell?
01 Mar 2021 14:54 #200700 by salvuz
Greetings everybody,
I know how to start program run by shell:
halcmd setp halui.program.run true
But it executes all the G-Code from the start of the program.
Is there a way to specify a certain line from which to start?
Like you do in AXIS GUI when you right click on the line you want to start from, and click on "run from here", but from a command prompt?
Thank you!
02 Mar 2021 22:49 #200841 by andypugh
Replied by andypugh on topic Run program from line... from a shell?
Interesting question.
I thought that it might be part of axis-remote
linuxcnc.org/docs/2.8/html/man/man1/axis-remote.1.html
But apparently not.
You can do it from linuxcncrsh:
linuxcnc.org/docs/2.8/html/man/man1/linuxcncrsh.1.html
And that does it here:
github.com/LinuxCNC/linuxcnc/blob/master...intf/emcrsh.cc#L1173
And that called function, sendProgram is found in halui and emcsh too.
But halui always starts at line 0:
github.com/LinuxCNC/linuxcnc/blob/8e38c4..._intf/halui.cc#L1688
So, basically, starting from a different line is supported at the lower levels, but it isn't entirely clear how to get to it from the command line.
03 Mar 2021 21:54 #200946 by newbynobi
Replied by newbynobi on topic Run program from line... from a shell?
If you are willing to use python, it can be done nearly easy. You may look at the code of gmoccapy for that part. Should be something line on_btn_runfromline_clicked or so. I am not on my pc so I can not look at the exact name of the Def.
Norbert
Time to create page: 0.173 seconds
