Linuxcnc with Computer Vision …
5 years 7 months ago #200918 by Hamel2020
As I know there was no enough topics about this subject , but I’m working on idea that ,
We know that the deviation in z direction for plasma cutting can be solved by THC , floating head ..etc , but I’m working on a welding machine , where the deviation on x, and y will be more .
So I used python openCV , to measure this deviation , and I was able to get the difference dimensions in x,y .
But I was not able to update the G-code simultaneously .
Any idea to update the g –code …
5 years 7 months ago - 5 years 7 months ago #200942 by tommylight
No need to change gcode for that, have a look at external offsets, should be much easier to get to what you need.
linuxcnc.org/docs/2.8/html/motion/external-offsets.html
PlasmaC should be already using external offsets to give you a starting point.
Last edit: 5 years 7 months ago by tommylight. Reason: typo
5 years 7 months ago #201015 by snowgoer540
tommylight wrote: No need to change gcode for that, have a loot at external offsets, should be much easier to get to what you need.
I swear I replied with essentially this same thing last night. I must have never clicked send then closed the browser without realizing...
5 years 7 months ago #201031 by Hamel2020
Hi .. Tom
This is a good advise to start , but as I watched some video , all external offsets was controlled manually , as explained i will use it for a welding machine as a tracking sensor for the welding gap ... still the idea not clear for me how to integrate the feed back from openCV to external offset to effect the motion of x, y simultaneously .
5 years 7 months ago #201032 by Hamel2020
never mind ... thank you
5 years 7 months ago #201062 by tommylight
Did you make the same typo ??? :) :)
loot...
Time to create page: 0.226 seconds
