Linuxcnc with Computer Vision …
  • thefabricator03
  • New Member
  • New Member
5 years 7 months ago #203502 by thefabricator03
Replied by thefabricator03 on topic Linuxcnc with Computer Vision …
Hamel2020, did you get it to work? If so how successful were you? I plan to do something similar using a THCAD10 as the welding sensor.
5 years 7 months ago #203563 by Hamel2020
Hi …
Actually I’m still working on it … I was able to read the distance (gap-welding width) between the two plates as the photo , I used the external offset as Tommy advise , but the offset examples in axis is limited specially for sine oscillating motion damping in Z-direction , ( this will be helpful in case of plasma cutting ) but for welding need damping in XY-direction .
Still I need the convert the image reading into a voltage signal to indicate the max_lim and min_lim for the damping oscillating .
I used opencv and python
  • thefabricator03
  • New Member
  • New Member
5 years 7 months ago #203566 by thefabricator03
What kind of camera are you using?
5 years 7 months ago #203567 by Hamel2020
this one
  • thefabricator03
  • New Member
  • New Member
5 years 7 months ago #203568 by thefabricator03
Very good, please keep us updated of your work. I would be very interesting in seeing this working!
5 years 7 months ago #203658 by Hamel2020
Sure I will
The following user(s) said Thank You: hairy
