XHC-WHB04B-6 - Handwheel doesn´t respond
5 years 7 months ago #201053 by Cadic
Hi there.
I´ve got problem with hxc-whb04b-6 handwheel. I try install it according to the instruction from video
of talla83 (
) - everything goes well, but at the end, if I
try to start LinuxCNC, 95 percent of lines report an error - halui.machine.on does not exist, halui.mode.is-manual
does not exist etc.etc.etc.)
So I try to remove that halui line and LinuxCNC works, but handwheel not.
In hal configuration every single button works red/yellow light, but only jog counts not. If i try in terminal command
xhc−whb04b−6 −ue , everything respond. But if I start linuxcnc, handwheel does nothing. On handwheel display I can
change axes etc. but machine doesn´t move.
I attach my files below.
Can someone please help me? Thanks.
File Name: Router_1.hal
File Size:4.3 KB
File Name: Router_1.ini
File Size:3.4 KB
File Name: xhc_whb.hal
File Size:12.15 KB
5 years 7 months ago #201064 by newbynobi
As your first counts goes only to axis counts and not also to joint counts, you will only be able to jog your Machine after homing, as prior to all homed axis counts are ignored.
Norbert
5 years 7 months ago #201065 by Cadic
Hi Norbert, thanks for answer, but machine does not react after homing too.
5 years 7 months ago - 5 years 7 months ago #201066 by Hakan
You can not change those 20 first lines, they must work.
Don't take the pins away from the signals and expect it to work.
There was a case just the other day here.
Rename the signal net.machine-on to net-machine-on.
Then, which is the next one that gives an error?
Copy that error here
Last edit: 5 years 7 months ago by Hakan.
5 years 7 months ago #201083 by Cadic
Hello Hakan,
if I use - hal example from - linuxcnc.org/docs/2.8/html/man/man1/xhc-whb04b-6.1.html
I have this error on 95 percent of lines. - ./xhc_whb.hal:x: Pin halui.xxx.xxx does not exist
I will be very grateful for any advice.
File Name: xhc_whb_20...3-05.hal
File Size:8.37 KB
File Name: Error.txt
File Size:5.27 KB
5 years 7 months ago #201086 by tecno
It looks like you do not have any signal for machine on/enabled in your router_1.hal
Time to create page: 0.437 seconds
