Agregar pines o parámetros al archivo hal
- Profed81
- Visitor
09 Mar 2021 04:04 #201513
by Profed81
Agregar pines o parámetros al archivo hal was created by Profed81
To add pins and parameters to the hal file, do I need to add it from the terminal ?. Or directly editing the hal file?
- Thank you received: 7468
09 Mar 2021 13:47 #201542
Replied by tommylight on topic Agregar pines o parámetros al archivo hal
Editing the hal file.
For testing you can add them to the "machine>show hal configuration" while LinuxCNC is running.
The following user(s) said Thank You: Profed81
Time to create page: 0.107 seconds
