power switch toogle with pendant
- mb_cnc
16 Mar 2021 03:38 #202443
by mb_cnc
power switch toogle with pendant was created by mb_cnc
Hello, I've been working on a physical momentary switch for toggling machine power and I have it working but when adding a second device to do the same (xhc-wbo4b-6 pendant) I'm getting "can not add output Pin" error. I think I understand the error just not sure the fix.
thanks
main.hal
net machine.is-on halui.machine.is-on
net machine.on halui.machine.on
net machine.off halui.machine.off
whc-whb04b-6.hal
net machine.is-on whb.halui.machine.is-on
net machine.on whb.halui.machine.on
net machine.off whb.halui.machine.off
custom_postgui.hal
loadrt toggle count=1
loadrt toggle2nist count=1
addf toggle.0 servo-thread
addf toggle2nist.0 servo-thread
#machine power on toggle button
net power-on-btn toggle.0.in hm2_7i76e.0.7i76.0.0.input-15
net toggle-button toggle2nist.0.in toggle.0.out
net machine.is-on toggle2nist.0.is-on hm2_7i76e.0.7i76.0.0.output-00
net machine.on toggle2nist.0.on # error on this line
net machine.off toggle2nist.0.off # error on this line
thanks
main.hal
whc-whb04b-6.hal
custom_postgui.hal
- Thank you received: 2165
16 Mar 2021 07:50 - 16 Mar 2021 07:57 #202457
Replied by Aciera on topic power switch toogle with pendant
The problem is that you are trying to wire two different "out" pins to the same signal: machine.on and machine.off respectively.
You could try and use an 'or2' component to connect the two sources to toggle the signal.
loadrt or2
addf or2.0 servo-thread
net button-1 or2.0.in0 <= hm2_7i76e.0.7i76.0.0.input-15
net button-2 or2.0.in1 <= your button on the pendant
power-on-btn toggle.0.in <= or2.0.out
Last edit: 16 Mar 2021 07:57 by Aciera. Reason: Got it all wrong the first time around.
- Thank you received: 4651
18 Mar 2021 01:05 #202691
Replied by andypugh on topic power switch toogle with pendant
I think this might be a job for
toggle-to-nist
Possibly with two buttons or-ed together.
You can also do this with LUT5 Which is a really useful component especially when you feed the output to one of the inputs (as you would need to do for this job).
LUT5 will either make perfect sense to you immediately, or not. But it would allow up to 4 buttons to toggle the state, with the additional flexibility that some could be set up as on-only and some as off-only.
Time to create page: 0.072 seconds
